Old 06-24-2013   #21
Default Re: Wtb Dewitt's radiator and spal fans
Originally Posted by tf95ZR1 View Post
Hey be careful, GC.
Aren't they a supporting vendor here?
Don't want to be banned.....
Oh wait, you're a mod!
No Idea reguardless they should have told me when I paid them it would be a week before it went out the door.
Old 06-26-2013   #22
RHanselman
RHanselman's Avatar
Take a look at this guy's custom Dewitt unit... Pretty slick...
http://forums.corvetteforum.com/c4-f...-corvette.html
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 06-26-2013   #23
Thats a little more than I was looking for Ron. However, for that application it sure made his clearnce issues go away. IM sure that was not cheap. GC
Old 07-05-2013   #24
RHanselman
RHanselman's Avatar
Yep I figured but it is cool no pun untended... Not cheap is probably right...
Did you get a chance to install? I'm interested in your results.
Cheers,
Ron Hanselman
Founding Member #80
Old 07-05-2013   #25
Yep installed resolving an AC issue at the moment although
Old 07-07-2013   #26
vilant
Was curious, if you the saw the post (can't remember where or who did it) where they removed sections of the front wheels wells with screen to help bring in air flow to the engine compartment. Have you done this mod? It may help keep things cooler in those hot desert climates your driving in.
Old 07-07-2013   #27
I have the Ron Davis in my ZR-1
The Ron Davis is a racing radiator that has 5 cores as compared to the stock 2 core. As a "racing radiator" it performs best at racing speeds where air velocity is high. Being thicker, actually makes it more resistant to air flow than the 2 core radiator.
A simple but effective modification that yields significant results, is to drill 3 or 4 holes in the thermostat flange, just inside of the seal contact area. This modification reduces back-pressure for coolant passing through the radiator & thermostat and therefore allows more flow coolant through the radiator, instead of the bypass. Bypassed coolant means hotter temps.
I strongly suggest you perform the t-stat modification before spending a lot of time & money on expensive radiators and fans.
As a side note, the only way to insure the stock radiator is as effective as it can be.... is to remove it and insure all the gravel & debris is removed and the vanes are reasonably straight.
Old 07-08-2013   #28
Well Everthing is in I will give you my impressions after the drive home. AC issue was a pressure switch leaking next to the suitcase.
Dewits drilled out the spal fans brackets backwards which was a PITA. Had to reverse the back and tap and die them out the other side.
GC
Old 07-18-2013   #29
Well went with the all Aluminum 2 row and the spal fans. Solved my cooling problem so far in Phoenix. I also installed the R Woods 160 degree thermostat I have had for several years in my parts bin.
Two Mondays ago Freeway reading on I-17 for the outside temp on the HVAC controls swung from 122-119 on the drive home on that day the raditaor rose to almost 75%-80% of temp band prob 225. AC was on full.
The Fans roar with a pitch that you normally hear on the newer cars (Plenty of air movement). You will gain a little more room in the front of the motor as the back side of the OEM shroud with the OEM fans are no longer used. The receiver drier needs to shift a little towards the passenger side but the same bracket can be retained.
Notes on this project: There is a 2 week flash to bang time for delivery once you pay. I learned this the hard way, Also as mentioned above the SPAL Fan brackets mounting screwholes were made upside down from the factory so we had to retap and turn the bracket the right way to get it to work. Kind of a PITA
Plan on spending $900 in parts just to do this project. There are no discounts. I'm happy with the results however beware of the timelines and problem issues.
I also do have one additional comment. If you are running a bone stock LT5 the stock factory radiator if its clean and free of debris, silt and sand will work well. I did not have cooling problems until after I stroked my motor, installed bigger inake cams etc. This stands to reason more HP requires better cooling options than stock. The same logic follows for beefing up braking and the rear end, transmission etc to handle the extra HP and Torque. GC
Old 07-18-2013   #30
RHanselman
RHanselman's Avatar
Default Re: SPAL FANS and 2 ROW DEWITT'S TECH Notes
Daryl,
Just wondering, what kind of HP/TQ you getting from that 380?
Ron Hanselman
Founding Member #80
