Alright all,
I just installed new: clutch master clutch slave clutch line transmission with 32,000 miles (operated fine when pulled I start it up and there is a obvious whine. when i push in the clutch whine goes away. did not have a whine before. *possibly a need for more bleeding of the clutch??? ![]() |
#2 | |
![]() Join Date: Oct 2004
What about throwout bearing?, How can I check to see if that is the cause?
I've never done it but I don't know why you couldn't use a stethoscope on the fork and just in the general area of the flywheel-housing and the transmission itself. I would think the stethoscope on the fork would be the first place I'd go.
![]() Join Date: Aug 2006
http://www.powertorquesystems.com/Co...rvetteMain.htm
If pilot bushing Jim sells solid and fluted. If TO bearing you are going to have to hunt for awhile - tough to find. |
![]() Join Date: Dec 2003
We have the fluted AC Delco bronze pilot bearing too.
http://jerrysgaskets.com/store2/root...roducts_id=780
Jerry,
Dont know if thats the problem,..but cant hurt to have one, Get me a price for both pilot and throw out bearings. ![]() |
![]() Join Date: Feb 2006
The pilot bushing is not in play here - all rotating parts are at the same speed (crankshaft, flywheel, tranny input shaft).
#10 | |
I also didn't see any mention of what had or hadn't been replaced other than hydraulics and was the transmission the one that was in the car or a replacement from another car with the 32K miles. That's a little vague. If the flywheel housing was removed and the transmission is from another car it may not like the orientation to the center-line of the crankshaft. I've never seen it mentioned when doing anything with an LT5 but what about offset flywheel housing dowels** ** is there dowels? Just askin' Last edited by WVZR-1; 07-31-2013 at 11:42 PM. |
