Old 08-29-2013   #1
Default Re: Bilstein FX-3 Actuators
Originally Posted by vilant View Post
Was hoping someone had the manual, I'd like to know what pins do what on the connector (maybe when one pin has voltage or ground it drives the motor CW and another pin does CCW. I guess I could disconnect the connector and meter each pin out, PIA though) . Since it's probably broke I'll take the one apart and see if anything is visibly wrong. Hopefully I can repair it instead of buying a new one. If you don't mind me asking, how much does an actuator cost? Thanks for info, you da man. .
When you figure out the electronics of the actuator....post up so I can fix mine
Couple hundred for two actuators
