Old 09-11-2013   #81
Default Re: Oil in injector housing?
Originally Posted by efnfast View Post
Soooooo, I've got 91 IH coming for my 90. That means I need to do something. Are we still using freeze plugs, or have we come up with something better? Thanks Locobob for the heads up on this. This would have been a big stumbleing block trying to do this over a weekend.
Yep....this thread is a bit old but the technology stays the same
Adapting 91 IH to 90 Heads.
Three Dorman 550-013 plugs (two plugs drilled 7/32) were used to restrict IH PVC ports of the 91 IH (90 Heads do not have the required restriction).
Old 09-12-2013   #82
efnfast
Thanks Cliff, I've got some 550-013 and 550-012 on the way. This would have brought my weekend project to a grinding halt. I ASSUME I cannot pop the old ones out of the original IH?
Old 09-12-2013   #83
I never gave that a thought....hummmm? I am thinking they do come out? I can't remember, but we did have a thread that discussed exactly how much trouble it was on the assembly line to do the 90 oil vapor holes. I just don't remember all the particulars.
Sorry I'm so forgetful Steve!
Old 09-12-2013   #84
You could remove the baffles from the 1990 housings, but they would not fit into the 91 housings without machining. The drive plugs fit the cast hole as-is.
Old 09-12-2013   #85
efnfast
Thanks guys.
Jerry, I still have to put an order together for you. I think I have a side line on injectors. -Steve
Old 11-14-2013   #86
efnfast
Ended up using the Dormann 555-012 plugs. flattened them in a vise to make them slightly larger in diameter. Drilled 7/32" holes in two of them and drove them in place with a 3/8" extension. Looks good, lets hope it works good.
Old 07-25-2014   #87
Someone had asked about the plenum and IH I have for sale. They have a 90 and so the issue of oil port restriction came up. Searched the forum and came up w this thread. For grins, and since different people were using different sized Dorman plugs, I decided to measure the 2 sets of IHs I have.
One is a NOS w a manuf date of Sept.89, the other was on a motor and they were made 1 year later. Here's a picture comparing the two ports.
The dimensions are 1 5/32" 29.32mm
1 1/32" 26.25mm
The larger ports are the earlier NOS IH.
Old 07-25-2014   #88
The top picture is of the same injector housing used for 90~92. The machine work to increase the port diameter to 1-5/32" is obvious and was done at Mercury in preparation for the baffle to be installed. The baffle was just never installed and it would work just fine on 91~92 models, just as it is, without the baffle installed. Some like this were probably installed on early 91 engines.
The bottom picture is of an "un-machined" port and would have been installed on 91~92, (can't see the injector bores so I am assuming it's the 90~92 style).
Old 07-25-2014   #89
Jerry,
Correct, they are both 90-92 style injector housings.
