#51 |
![]() Join Date: Jul 2010
Do we really even require siamesed ports anymore? Just going by tpepmeie's high output427, 638 rwhp(on chassis dyno) and 702hp at the crank 700hp from 6500-7000rpm & 588lb/ft torque(engine dyno) while running short of injector.
#52 |
![]() Join Date: Jan 2010
Thank God!!!!! I knew this siamesing was $$$$$. I'll just get it dynoed, figure out any bugs & if it's not up to snuff, I'll go see my buddy Pete!
#53 | |
![]() Join Date: Jan 2004
I think the stroker "starves" for air running off the tiny little primary port and then all hell brakes lose as the secondaries crack open for what you pay to modify a stock intake, a hogans would be cheap I think LPE charged about 4k to do the bifurcation job welding up a sheet metal intake isn't cheap, but it's not rocket since either I'm seeing more "billet tubes" that are CNC machined and then welded to the base. cool stuff. like to do a 3D carbon fiber printed intake someday. it would take a bit to do the CAD, and the 3D printers aren't cheap, but they are getting more affordable all the time. you could design a much better shaped port with the right taper and plenum volume sized to the displacement for 7500 rpms and my bet is that it would work quite well. even the "crab style" cross ram would look very cool and as long as the tubes are small enough it should build great port velocity the LT5 intake has WAY too many turns and pinch points to really flow well up top due to the compromises for the packaging and injector housings it looks cool, but me thinks we can do better with the modern high tech equipment the nylon stuff on the LS motors is light, rejects the heat, and flows pretty decent without all the hassle. but the casting process is expensive to tool up and it would be tricky to make the more I learn about the carbon fiber and 3d printing, the more I get excited about it. it's gone from "prototyping" to "small volume manufacturing" which is exactly what us LT5 guys need for a bunch of the parts no longer made can you say "group buy" they we digitize and make up whatever we need. the technology is getting cheaper and easier to use every day. it's the bomb ![]() ![]() ![]() ![]() |
#54 |
![]() Join Date: Mar 2007
I have seen a few of the "siamese" intakes, seems that they forgot to port them first....my whatever the hell you want to call it has more volume
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-16-2013 at 11:42 PM. |
#55 | |
![]() Join Date: Dec 2003
Some like the Siamese look. POLO 1 ![]() Pete
#56 |
#57 |
Tags |
ported heads, porting, siamesed |
