Old 09-19-2013   #21
scottfab
scottfab's Avatar
Default Re: Help Again
He disappeared.
Think he's pissed since we told him he had to post better to understand...
He has probably gone to someone else to do the work or....
the problem went away for a bit. It could be intermittent.
He not likely to be fragile as some when it comes to suggestions
for clarity and correctness.
Scott
Old 09-19-2013   #22
Racinfan83
All I can say is that I don't care how bad your "computer skills" are - but if it is unreadable and basically non-understandable - you shouldn't even expect the caliber of answers you guys provided. When I saw this at first I expected nobody to reply. The fact that you attempted to help him out says a lot. So does the fact that apparently he is offended that someone mentioned the fact he needed to explain himself. I'm not the perfect orator, and won't ever claim to be - but at least I try. That guy didn't even TRY to post legibly....
Old 09-19-2013   #23
no sense piling on here guys. the point was made and then repeated. we're all here for the same reason, to help where we can, lets just move on and hope he fixed his problem
Old 09-20-2013   #24
carmine
Im not pissed Just can`t Type Correctly
carmine is offline   Reply With Quote
Old 09-20-2013   #25
scottfab
scottfab's Avatar
Great to see you back !
We're here to help with ANY ZR-1 issues.
Please ignore the hidden agenda some may have trying to get
political leverage or point out that you were being abused.
They have anger issues.
As someone just mentioned all that is required is that we be
able to understand what's up. Perfect typing or grammar is not required.
When ever you're ready to get back on it we'll be here.
Knowing you are using a phone to communicate we understand
the difficulty. If needed we can also
explain how to post pictures here.
Scott
Old 09-20-2013   #26
carmine
thank you`i`ll be back
Old 09-20-2013   #27
Schrade
YES SIR!!!
Makin' any progress on it there Carmine?
ed.:
Even one letter can confuse:
http://www.zr1.net/forum/showpost.ph...2&postcount=10
