Old 10-16-2013   #11
rikker
Default Re: new owner 1990 zr1
ITS OUT AND REALLY DIRTY, ANYONE KNOW IS THE WATERPUMP SOMETHING I SHOULD DO WHILE IM IN THIS MESS.
rikker is offline   Reply With Quote
Old 10-16-2013   #12
only if it's leaking.
Old 10-16-2013   #13
Schrade
Welcome onto the boards there...
Old 10-16-2013   #14
PhillipsLT5
PhillipsLT5's Avatar
Keep cleaning until you can see some good light from behind or better yet, get a new & or alum rad, why put a old rad back in, just asking for another rad pull soon
Old 10-17-2013   #15
rikker
I was thinking same thing,sometime I go over board and replace things that don't need it, rad is in great shape though ,but gonna go new along with the hose kit from marc and possible wpump.
Old 10-17-2013   #16
bradley
if you do the water pump be very carefull. as the bolts MUST go back into the hole they came out of.
bradley is offline   Reply With Quote
Old 10-17-2013   #17
rikker
Hi trying to find out info on this procedere, have you done one and how difficult is it?
Old 10-18-2013   #18
Default Water Pump Installation
I use a very thin coat of Permatex 300 Form A Gasket on each side of the Water Pump gasket and IH coolant manifold gaskets (unless you have eliminated TB coolant) before installing. I use a drop of Blue Loctite 242 on all water pump bolts and torque all water pump bolts 18 ft-lbs. NO LEAKS
Now if you get confused on which bolts go where......just insert the bolt and if it sticks out about 3/8 inch to 1/2 inch you have the correct position for that bolt
Old 10-18-2013   #19
Default Re: Water Pump Installation
Didn't someone just post in another thread that the bolt sizes noted in the FSM are indicated incorrectly? --Bob
Old 10-18-2013   #20
Did you pickup a new radiator?
