We all know our belt tensioner is rarer than a supermodel at a buffet. The GM/ACDelco part has been discontinued as have all aftermarket variants, including the one by Dayco. I had previously verified with Dayco that the L98 tensioners have the same internals as our LT5 tensioner but Dayco has since discontinued the L98 tensioner as well. You can however find an L98 tensioner in the aftermarket world and you can use the internals to rebuild the one for your LT5. FYI, Dayco still (01/24/25) makes the LT5 pulley, Dayco #89003.
Photos of OEM LT5 Tensioner, GM # 10067479 Available Parts as of 01/24/25: L98 1988-1991 Belt Tensioner, Zip Corvette # FB-449 L98 1988-1991 Belt Tensioner, Ecklers # EK-25-112206-1 L98 1988-1991 Belt Tensioner, DRIVESTAR 10055897 I wanted to make sure to use basic tools with this rebuild so the average person could do it themselves at home. Please see the graphics I made showing the parts Disassembly of the L98 unit w/ plastic cover is fairly straightforward: 1) The black plastic cover just pries off with a screwdriver, do so carefully, making sure to distribute force from one side to the other. (as a safety precaution I wired the unit together before prying, unsure of what would happen once the plastic cover was removed; I was pleased to find it wasn't as difficult as I thought and the wire wasn't really necessary). 2) Once the plastic cover is off, remove all the components except for the heavy duty spring and set aside in order. Then, use a chain wrench (or strong strap wrench will work) to take the tension off the spring stop. 3) Once the tension was off the spring stop, I used the wood handle of my hammer and gently tapped the spring assembly back so the stop would not make contact anymore and I could unload the spring tension. 4) Once the spring is unloaded you can remove the spring from the housing; I did this by tapping the exposed part of the spring with a hammer while also putting a screwdriver through the small hole on the backside to tap the spring. Disassembly of the LT5 unit is only different as the cover is aluminum and tighter: 5) I used a puller with a 1/4 socket (or one a little smaller than the center pin) to press against the center pin. If you use a two jaw puller, make sure the jaws fit in the grooves. (you should be able to rent a puller from an auto parts store or buy a cheap one at Harbor Freight and grind the jaws to fit in the groves). 6) Repeat steps (2), (3), and (4) with the LT5 tensioner Assembly 7) Replace all of the old, internal components with the new L98 ones but re-use the LT5 aluminum cover.. When you install the new spring, use a large pair of pliers or something of the sort to compress the spring slightly to get it into the housing, it doesn't take much. I also held the spring vertically to keep the Teflon tape from falling out. David Hetrick (edited by ZBrink for added clarity) Last edited by ZBrink; 01-24-2025 at 12:23 PM. Reason: Edited title, numbered the steps for clarity, deleted outdated info |
Nice project well done
![]() Any thoughts of doing a run of these? Im sure they would sell quick. I would be in for a spare
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 12-04-2013 at 01:36 PM. |
I don't have any used ones to rebuild, and you cant find them. BTW here is the link to the cheapest Dayco L98 tensioner I could find.
Dave (01/24/25 - Part has been discontinued; ZBrink) Last edited by ZBrink; 01-24-2025 at 12:51 AM. |
![]() Join Date: Jul 2007
I have a used one I need to rebuild...
Im thinking the same I think I have used one as well
Ill tell you what if one of you guys buy the new Dayco and mail me it and you old one I will rebuild it and mail it back for the one that is on you car now. I have a good friend in Japan with a Z that's been down cause of catastrophic failure of his ZR1 tensioner. That way I can rebuild the traded one you give me so I can rebuild it and gift it to him. A perfect brotherhood circle.
Dave |
![]() Join Date: Apr 2004
![]() Join Date: Feb 2011
Gonna have to try this. I have one with 30k on it that sometimes sticks a little, but isn't completely worn out. I was able to buy one of the last new ones for $199 and was happy to get it at the time.
Wow!!!! $57 bucks. But it will work.
#10 | |
Dynomite Have I mentioned lately that you rock
