Old 02-27-2014   #11
Default Re: fuel sending unit and pump
I agree. The strainers should be swapped out too. Most pumps come with one.
Scott,
Thanks. That's exactly what I was talking about. As the strainers get clogged the pump works harder. I'd suggest this could be a reason for premature pump failures.
Old 02-27-2014   #12
raymond greene
Thanks guy's for all your help!
raymond greene is offline   Reply With Quote
Old 02-27-2014   #13
scottfab
scottfab's Avatar
Scott, Are you currently using these or know someone who is without any issues?
Yes, I have two of those in mine car now. BUT I also put in a switch to activate pump #2 at will such that if pump #1 fails I can get home using pump #2.
Way back when I first got the car in 97 I had pump #1 fail.
The symptom is the car starts fine but will only run about 30 seconds (until the pressure drops in the rail).
Scott
Old 02-27-2014   #14
Schrade
YOU HAVE A MODIFICATION IN YOUR Z???
j/k there Scott - no personal attacj, trolling, offense intended
Old 02-27-2014   #15
I noticed that also.....does not jive with his TAG.....
Oh...wait...the LT5 is NOT modified by the switch.....so he is still OK
Just some friendly ribbing
What is the source of these filters?
Thanks in advance
I notice two different filters on fuel pumps on right and identical filters on fuel pumps on left (the black rubber clip is missing).
I assume these filters on the left will not fall off?
I assume both filters except the bottom one on right are kept on solely by friction fit of metal cup on the plastic?
Old 02-27-2014   #16
Schrade
Uh-oHhh - friendly ribbing.
See ya later Cliff.
Old 02-27-2014   #17
See ya later Cliff.
Oh.....Hmmm - u started it
WE both might be seen later
Old 02-27-2014   #18
Schrade
I and several others had issues with the Airtech units, listed at AutoZone as the replacement for the pump. FYI.
+1 there...
DO stay away from AirTech.
I put one in my '98 GMC, against others' advice on GMC boards (because I keep tank FULL - which IS supposed to make a difference), and it failed post 2 years < 10k miles.
Yeah - but I'm special.
No, NOT special ed (as far as you know).
Old 02-27-2014   #19
scottfab
scottfab's Avatar
What the HELL is your problem
Kidding...... ha
Many that have been around since the 90s know that I have MANY mods to my car. In fact I pioneered some and ALL are well documented in my FSM. To be sure all are easily removed except the Corsa exhaust. I kept the original exhaust. Again, there's nothing wrong with mods or even trashing the car if you want to. Talking others, especially newbies, into doing the same without presenting alternatives is what I have an objection to. And I sure want to be able to use "I disagree...." or for the more sensitive folks "I beg to disagree..." or "I humbly disagree...." etc. when I want to present those alternatives.
It's all about respect, giving and receiving.
Scott
Old 02-27-2014   #20
OK
