Old 04-14-2014   #11
scottfab
scottfab's Avatar
Default Re: LED Headlights for our Zs
Along with much longer life and usual increase in light output, not to be forgotten, is that as you convert more bulbs to LED the less draw on the alternator and therefore less of a leaching of HP from the LT5.
(makes for more current available for cooling boxes etc on long trips)
The other phenomenon is the available selections of color temperatures, everything from "Warm White ~3000K" to nausea inducing "Xenon White 20,000K" and everything in between.
I've been following the LED technology now for many years. What's been happening is a bifurcation in the market needs. On one end is the extreme efficiency LEDs and at the other is the extreme high output ones. The later sacrifice efficiency for better thermal dissipation characteristics. (heat tolerance etc) The high heat ones use ceramic composites and an RTV like compound. That way they can drive the piss out of them and use heat sinks and/of fans to keep them cool.
I am fairly sure over time we'll see incandescent, CFL, HID, Halogen and other bulbs go the way of vinyl records. They'll still be around but only for nostalgia and other (like NCRS) specialty purposes.
For a similar historical transition talk to someone that went through the transition from kerosine lamps to electric.
My brother has a father-in-law that can still remember rural places in Wash St. that went through that transition.
Scott
Old 04-14-2014   #12
8cam
While LEDs are cool, the technology is still young and there are far more cost-effective alternatives these days. A set of E-code housings with glass lenses, high-wattage H4 bulbs, and relays, will cost less and provide far better lighting. Good reflector and lens design, coupled with proper adjustment will get you better results than most "upgrades" out there. I do this in all my cars and the difference is just phenomenal.
Old 04-14-2014   #13
Fully Vetted
Fully Vetted's Avatar
I went LED on my Wrangler and couldn't believe the difference. Even over my HID's on my F150. I love them. They were about the same price as the ones for the Z. A little more actually.
Previous owner did HID's on my Z but I'll be looking into these LED's for sure.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 04-14-2014   #14
Actually you are refering to the $99 and less Ebay HID kits. My kit was plug and play from CorvetteHID.com including the ballasts. All 'Kits" and I use that term loosely are NOT the same.
Neat with the LEDS. I was wondering when that was going to come along. I wonder if they use one large LED or multiples to acheive ALL the light? I wonder if the housings are plastic.... I hate those as they tend to haze vs. glass
Daryl,
Did your kit come with reflector optimized for HID bulb? Fully understand your comment that there are kits with varying level of quality. My concern was more of reflector quality. Even if I went with quality reflector such as Hella, due to difference in bulbs between halogen and HID, resulting light from reflector may not be what was intended.
Reason I am hopeful with GE LED is based on an assumption that the light source (LED) and reflector must have been designed with quality engineering with GE's reputation on the line.
There may be HID kits engineered properly. It is just very difficult to know what you will be getting.
Old 04-14-2014   #15
Fully Vetted
This may not matter to some but there's the whole law issue as well. The LED's are DOT approved.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 04-14-2014   #16
Daryl,
Great point mine are glass projector housings. You truly get what you pay for. GC
Old 04-14-2014   #17
Are they glass or a plastic lens?
Old 04-14-2014   #18
GE website FAQ says "
Are these LED lamps Legal?
YES. The GE LED Headlamp exceeds the DOT requirements for on road use"
http://www.gelighting.com/LightingWe...eadlights/faq/
Old 04-14-2014   #19
scottfab
scottfab's Avatar
Good find.
Good stuff.=D>
Scott
Old 04-14-2014   #20
Schrade
If the amp draw on the alternator is less (whatever the difference is, between a car equipped with LED headlamps vs. standard lamps), then should the CS 144 Z alternator be replaced, with a LOWER amp output alternator?
Question is, when the ECM decides that the 'clutch mechanism', in the alternator, that has to engage, and become more of a load on the motor, ... ?
The alternator is ALWAYS spinning...
How DOES the integral voltage regulator work, I guess, is the question???
