Old 04-16-2014   #21
TheBlackPearl
TheBlackPearl's Avatar
Default Re: Oil Pressure
I did the test today, right on start up i got 65 psi, within 2 minutes it started to drop to 62 psi before i turned it off. It's about 46 out right now. Are these roughly the same numbers you were getting csavaglio?
TheBlackPearl is offline   Reply With Quote
Old 04-16-2014   #22
csavaglio
Looks like you're dead on for what I saw and what's expected if it's working right. My cold idle was 65psi and fully warmed up was in the low 20s.
I think you found that you have the same issue I have....the car's working properly but the sending unit isn't. Try the Echlin one and see what you come up with on the gauge. If not, pick up the more expensive Delco one.
http://jerrysgaskets.com/store2/root...roducts_id=106
Chris
Old 04-16-2014   #23
TheBlackPearl
Bought the Echlin one, i'll see how it goes when it gets here, most likely early next week.
