Old 05-09-2014   #1
Default Re: 93 ZR1.????
Rear spring cushions? Lose caliper?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 05-09-2014   #2
Route 66
Route 66's Avatar
Thanks for your thoughts. The spring rubber looks like it might be a possibility. Do you or might someone know where I can get new rubbers for the rear leaf spring...........Thanks Ellis...........
Route 66 is offline   Reply With Quote
Old 05-09-2014   #3
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F~~~
Steve
1990 Red/Red #1473
Old 05-09-2014   #4
nelson007
nelson007's Avatar
Spare Tire loose.
Nelson007
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
Old 05-09-2014   #5
Route 66
Route 66's Avatar
We Gone and Nelson007 thank you.. / I will look in to that tomorrow.
Old 05-09-2014   #6
Check your spare tire/hanger. Mine was loose and made a sound like that onece!
Old 05-09-2014   #7
Route 66
Route 66's Avatar
Thank you..
Old 05-09-2014   #8
When you get it figured out...let us know what it was
Old 05-10-2014   #9
Route 66
Route 66's Avatar
I will post it here. It might be a few days I will have to order the spring rubbers. ....Ellis
Old 05-13-2014   #10
I agree on checking the spare tire carrier, tire and bag. If you can push the carrier up a bit by hand that is probably it; tighten the bolt. If not, it might be suspension bushings. When I first got my 95 in 2012 (with 20k miles) I had a bump noise when I turned into my inclined driveway. Marc H had it in for servicing, thought the bushings looked dried out and replaced one or more (can't remember how many). After removal he said they did not look too bad after all, but the noise went away so that had to be it. --Bob
