Old 07-21-2014   #9
vilant
Default Re: Code 31 trouble
For you Schrade.
Just to clarify, I followed the procedure on the chart to the right when I first had a steady Code 31, which led to faulty cam sensor or cam sensor connection. Bought a new cam sensor, then it became intermittent. I just realized I can't "re-pin" the connector. I need a whole new connector instead. Instead, I tried cleaning the inside of female connector, used De-Ox, and bent them down a little bit for a tighter connection. The 3 arrows below are what I thought might be causing the intermittent. Also found I can't read what the cam sensor is doing on my scanner, it's just a malf flag (on my scanner at least). We'll see how the cleaning and bending works out.
