12-15-2014 | #1 |
Radiator options
Mine is leaking and I want to know is the factory unit a one or two row/core unit?
After reading Dominicks summary of the Fluidyne unit I do not see any advantages over the stock unit.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
12-15-2014 | #2 |
Re: Radiator options
The OEM & replacement radiators from chevy ( if they still have them? ) are a single core or just one row of tubes. They are not all that small, but them I'm sure the aftermarket units are double row units.
12-15-2014 | #3 |
The little that I know I believe oem use brass or copper which is much better than aluminum. I think that is the main reason for requiring 2 Rows which is to match the efficiency. The added cooling comes from the additional capacity. That's as much as I rebember when I researched into it but I'm going to be looking for a radiator soon myself because I'd like to move to an electric water pump as well.
12-16-2014 | #4 |
Actually the OEM and OE replacement stuff is aluminum. I don't know that even the aftermarket stuff uses any thing but aluminum.
The only rub with the ACDelco replacement units is that they are universal with respect to transmission. They all have the cooler in the right tank for the auto equipped C4's. The aluminum is not an issue as long as you keep up with coolant maintenance, keep the grounds clean, and have no gasket leaks. Tom
12-16-2014 | #5 |
My only issue with aluminum radiators like Ron Davis, is that they don't have a drain petcock. It makes draining a real mess.
Rich
12-16-2014 | #6 |
Thought I'd "weigh-in" on the radiator issue because, back in the late 90s, I did a lot of cooling performance development on ZR1s–including doing most of the product development for Fluidyne on its late C4 radiator.
First, the above comment about aftermarket radiators generally not having drains. Pure bunk. The Ron Davis might not have one, but most others such as DeWittt and Griffin and, also, the Fluidyne have them. The stock radiator is not copper-brass. It's an aluminum core with plastic tanks. The radiator is one places GM "cheaped-out" on the ZR1. The car should have received a specific radiator of all-aluminum construction. That would have allowed GM to have a slightly larger radiator for the LT5's extra power output and it would have allowed GM to reduce the amount of coolant bypassed around the radiator during high rpm operation. Lastly, the OP's comment about "Dominick" stating that the Fluidyne (or any other aftermarket radiator for that matter) being no better at cooling than the OE radiator is not based on any facts. Reality is that combined with a 180° or 170° thermostat and lower fan-on temps, the Fluidyne and other aftermarket C4 radiators are guide good at improving cooling performance.
12-16-2014 | #7 |
My comments regarding the performance of the Fluidyne dealt w the fact it was actually too good at cooling the motor. During a recent drive in 35F weather, the coolant temp had much difficulty getting above the temp for allowing Closed Loop operation. It worked fine in summer and fall temps. My OE radiator needed to be cleaned and I decided to swap in the Fluidyne for extra cooling w A/C. My wife won't get in the car during the summer unless I run the A/C.
I'm using stock thermo.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 12-16-2014 at 10:20 AM. |
12-16-2014 | #8 | |
12-16-2014 | #9 |
My Ron Davis radiator has a threaded drain port near bottom right hand (passenger) side
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-16-2014 at 10:44 AM. |
12-16-2014 | #10 | |
Rich
1990 Bright Red Coupe #608 380 Stroker, Ported Heads/Intake/Housings/TB Haibeck Secondary Delete Chip / Pete's Cams George Braml Intake / FIC Injectors Coated SW Headers / Corsa Bill Boudreau B/B ZF6 / Viper 4.10 gears Ron Davis Radiator Pioneer AVIC-Z140BH NAV Fikse FM5's 285 / 335 / C6 Brakes WAZOO Member Last edited by Scrrem; 12-16-2014 at 10:49 AM. |
