Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Detailing, Cleaning, and Waxing
Old 12-27-2014   #1
Billy Mild
Default Spot Repair vs. Dr. Colorchip
Has anyone tried using Dr. Colorchip? I have a few spots where chips, and some road rash are present. I would like to fix this, but I'm afraid a body shop will just want to paint the entire car.
I will try and get some pictures of the chips.
Old 12-27-2014   #2
efnfast
Default Re: Spot Repair vs. Dr. Colorchip
I've used it and been happy with the results. I don't think I could find the spots I did.
Old 12-31-2014   #3
I had excellent experience with the LANGKA chip repair kit, up to dime-size repairs, as well as a few scratches too. (see link).
The trick to any repair kit is the drying time of the paint - which varies with temperature and humidity. A little trial and error may be required, depending on conditions and the size of the chip, I found.
My introduction to the Langka kit was in response to being caught in a hail storm with my (then) black 95 Vette. As result, I had dozens of chips to practice on, but once I was done there wasn't a trace of the chips. It saved me from a repaint job: impossible to see the repairs!
Old 12-31-2014   #4
Domestic Power
Domestic Power's Avatar
Paul, did you use GM touch up paint along with the Langka kit ?, and sense we are talking about paint I have some chips on the edge of the throttle body so was wondering where I might get paint to match my 1990 Z's LT5
1990 Steel Blue #2818 ( stock for now )
Domestic Power is offline   Reply With Quote
Old 01-03-2015   #5
Yes - GM touch up paint. Now, I found the paint at WalMart ( in the automotive section, actually!), but I've seen the little tubes at auto parts stores, and also at a local auto body supply store. I'm sure you could get some at an on-line auto paint supplier too.
Old 01-03-2015   #6
Billy Mild
Should I try and detail the paint before or after I attempt to fix the chips?
Old 01-04-2015   #7
efnfast
Don't think it matters, but you certainly don't want wax on the area you are fixing.
