Old 03-11-2015   #1
Locobob
Default Ported Intake
Early style (90-92) ported plenum and injector housings for sale. Plenum ports are 36mm at gasket surface and grow larger upstream, inside of plenum has been extensively worked, corner bolt holes have been sleeved for alignment, throttle bores have been enlarged to accept 63mm throttle body. Injector housings are 36mm through secondary ports, secondary bosses reduced and contoured, primary ports are 36mm halfway down the ports and reduce to 34.5mm at head gasket surface for optimal transition to stock 32mm primary head ports, primary injector bosses have been eliminated.
Easy 25hp bolt on for stock LT-5. Exterior refinishing is recommended, can arrange top end powder coating for extra.
$1500 outright.
Robert
Old 03-11-2015   #2
Locobob
Default Re: Ported Intake
Robert
Old 03-12-2015   #3
efnfast
I bought a set of these from Locobob. No issues, and nice bolt on power. Thanks Bob. -Steve
Old 03-12-2015   #4
Jagdpanzer
Jagdpanzer's Avatar
Excellent work Bob!
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-12-2015   #5
Any trades for a stock plenum and housing? I'd be interested in the offset cost . Robert
Old 03-13-2015   #6
I think Robert said......on the "other Forum".......
Yes - forgot to post - $900 + shipping with core return.....
Just in Case Robert is off for the weekend
Old 03-13-2015   #7
efnfast
Gee, that might even be the core I sent him.
Old 03-13-2015   #8
Locobob
You would be correct Steve... not turning these out as fast as I used to.
Daryl - yeah I'll do $900 with exchange, do you have another Z or something? thought yours was already all done up?
Robert
Old 03-13-2015   #9
efnfast
If it matters, these came off my 90 with 61K on them. My new ones look most beautiful all powder coated and going down the road much faster.
Old 03-13-2015   #10
Vette73
Ok so if you send your stock plenum the cost is 900 plus the shipping?
Just curious....
