Return or feed line? And what year?
1991. I'm guessing it's the feed line because it's been leaking for the last 6 hours..
It's the line right below the passenger door. |
Okay I didn't realize there were 2 lines there. The one that's leaking is the inside one. So whichever that one is. It has finally stopped after about 10 hrs, and I am assuming my tank is empty because it was very low when it started.
Feed - 10052173
Return - 10052179 Both are discontinued. I'll check dealer inventory in the morning.... or a few hours actually. |
Damn... If they're both discontinued is there a way to repair them?
Thanks for checking man. |
I would not try to repair the line if I were you. You should try White racing, that is who I go to for discontinued stuff. Usually is not a hassle either. Good luck with the fuel line.
Sending you a PM with the contact info. There is 1 left.
