Old 05-17-2015   #1
Karl
Karl's Avatar
Default Motor Mount Picture Trying to fix lifting gearshift
Anyone have a picture of the LT-5 motor mount on the engine? I am trying to diagnose and fix a lifting gear shift under load. I got under the car and can see the bolt and nut from the bottom that go into the mount but besides that nothing much else to see. I can feel around and seems like there are a couple of bolts on top of the mount.
The C-Beam bolts are all tight except for one up front that I could not get to while under the car.
I also tried to lift the motor on each side with a piece of wood and it did not budge so it appears the mounts are good.
Thanks!
Old 05-17-2015   #2
Default Re: Motor Mount Picture Trying to fix lifting gearshift
Thanks!
Karl,
The C-beam bolts are the issue. Need to be torqued properly. Had same issue last year. Took it to Pete and we got it up on lift.
Old 05-18-2015   #3
Karl
Karl's Avatar
Pete thinks a bolt may have backed out of one of the motor mounts. The C-Beam bolts are tight.
Old 05-18-2015   #4
WVZR-1
This is the orientation for all LT series engines in the C4 Corvette. #1 bracket to the engine and the mount to the engine retained by the thru bolt:
http://parts.nalleygmc.com/showAssem...=0&modelYear=0
Old 05-24-2015   #5
Well...from what you describe, my money is still on the C-beam joint, probably the front (transmission joint) one. But, to find out for sure, I'd have to remove the C-beam and inspect the contact regions for scuffing, and/or distortion of the bolt holes, i.e., elongated holes, AND/OR a ridge around the edges of the steels washers is the dead giveaway the joint is slipping!
NOTE: Also, if the rear C-beam joint is slipping, the rear-end tends to kick out to the right under hard acceleration as mine also did. The cure for both for me was/is Boudreau's C-beam plates and some blue loctite to enhance friction between the mating surfaces (ref Bill Boudreau's ZFdoc.com site).
While the C-beam is removed, the motor mounts can be tested by attempting to rotate the motor from side to side by applying pressure to one side and then the other with a (bottle) jack. Any movement can be explored to assure it is only the rubber flexing, and NOT a securing bolt(s) or broken parts at fault.
Keep in touch!
Old 05-24-2015   #6
Karl
Karl's Avatar
I am going to get it taken care of. I have been working and driving my Prius.
Fun car, totally different vehicle though.
I took the Z out for a spin today and I plan on dropping the exhaust so I can not only get a full view of the C-Beam but to also de-grease and clean up the area. Last time I pulled my hand out of that area it was greasy, slimy and dirty.
Old 05-26-2015   #7
*... Last time I pulled my hand out of that area it was greasy, slimy and dirty.
Hmmmm..... Oil may well be a contributing factor in your situation. I'd definitely want to get the oil cleaned off - using some "CRC" (red can) de-greaser, and get the mating surfaces clean and dry again before torquing the bolts back down again.
Oh! And getting the C-beam centered correctly BEFORE torquing it down can make a difference, far as eliminating wear on the U-joints and/or eventual vibrations. (ref: Bill Boudreau, ZRdoc.com)
Old 05-26-2015   #8
Karl
Karl's Avatar
I fixed it yesterday. Took everything apart, cleaned and reassemble and no more lift.
if the weather holds I'm going back on the dyno
