#11 |
![]() Join Date: Jul 2007
I honestly don't want to sell it, I know not what you wanted to hear, I do want to get it fixed..
#12 |
Check Jerry of Jerry's Gaskets. I exchanged my old ECM for a rebuilt one last year.
#13 |
![]() Join Date: May 2011
Do you need it because your car is not running? Or, Do you need it as a spare?
#14 |
![]() Join Date: Dec 2007
Car is running but am getting a knock sensor issue code 43 replaced the sensor tested the run between the sensor and the ecm all are good ECM i think is the only thing left to replace.
#15 |
what about trying a different memcal. I seem to recall it has the ESC (knock) control on it..
#16 |
I'm running Marc's chip wont that by pass the factory chip?
#17 |
Depends.
Did you remove your memcal and replace it? or do you have a adapter board in the ECM? if you replaced it.. swap in your factory chip and see if the code is still there.. if so then ECM, if not, then I suspect the little PCB on the MEMCAL
#18 |
I have the adapter board "piggy back"
#19 |
okay.. check to be sure the MEMCAL is on correct and tight..
IF so get another MEMCAL to verify that is not the issue
#20 |
I will look for a new memcal its on right I have check it before thanks for the tip.
