Old 07-13-2015   #1
zr1esq
Default Re: A/C Compressor Not engaging??
Ok with ignition on and not running. I pulled the plug from the switch under the overflow tank and measured .578 volts. Then next to the motor, there are two more switches. again I measured .578 on one switch - the other switch I unplugged and the secondary cooling fan turned on. When I pulled both switches no voltage was measured at either switch. What do you think?
zr1esq is offline   Reply With Quote
Old 07-13-2015   #2
randy ransome
randy ransome's Avatar
Have you made sure the codes are erased.
My compressor wouldn't do anything either until the low freon code was deleted.
