Old 08-10-2015   #1
Jagdpanzer
Jagdpanzer's Avatar
Default Mystery Fire Wall Mounting Stud
Can anyone identify the purpose of the small mounting stud circled below? Its located on the firewall just inboard of the steering column.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-10-2015   #2
Default Re: Mystery Fire Wall Mounting Stud
They put it there to confuse engineers as they know no one else would even notice.
Old 08-11-2015   #3
WVZR-1
How about on an A4 car it's used inside the car to anchor the park/lock cable behind the accelerator cable bracket? If you look at the pedal linkage I posted in another thread you can see the perforation for it next to the pedal bracket studs on the plate. Is the angle deceptive?
Pure speculation but I did check eBay for a park/lock cable and I see an appropriate clamp.
http://www.ebay.com/itm/84-96-CORVET...-/121292195255
Here's a routing image from SPO
http://parts.nalleygmc.com/showAssem...riveLine=11463
