Old 08-11-2015   #1
efnfast
Default Re: Help with my LT5 Camaro conversion
I believe the throttle clips you are looking for come from Carter. aka Carter200
Old 08-12-2015   #2
Nice build,so nice to see somebody build a car NOT in the current build trend which is total $hit. I like the wheels,look like Budniks,came very close to putting a set of these on my car. The cable problem your having isn't related to the motor in the car. It takes no more effort to push the pedal in my Z than it does in an old Nova I have. I still get a kick in the a$$ knowing people are still putting these motors in projects. You might need to reroute your cables. As noted Carter makes a few items for the LT5 as well as some custom one off items per your request.
Old 08-12-2015   #3
perrymitchell
Thank you Jeff. You are correct, they are Budnick Gasser wheels that they modified for me by adding the perimeter bolts making them look like a 3 piece wheel. I know it's not the motor in the car that is giving me a stiff throttle, It's probably the pedal assembly. I may have to go with some kind of bell crank system. Thanks for your responses.
perrymitchell is offline   Reply With Quote
