Old 08-31-2007   #1
cuisinartvette
Default How many have the original motor...
Any idea of how many of these things had the motors replaced under warranty...Think it really matters if you have the original in the car or not??
Opinions...
Old 08-31-2007   #2
Corvette95
Corvette95's Avatar
Default Re: How many have the original motor...
I think it would matter in the less than 10k mile cars...otherwise no.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 08-31-2007   #3
QB93Z
QB93Z's Avatar
I agree with Corvette95 if you are an originality purist. But, it is possible that a really low miles early year car was never run enough to find the original defects. There may be problems that will appear that were never repaired by GM.
Old 08-31-2007   #4
Aurora40
Aurora40's Avatar
Does it make your car less original if it's a factory repair? I mean, that was the procedure. Anything wrong with the motor, even small stuff, and it got swapped out and shipped back. I would think if you could show it was done under the new car warranty, maybe it wouldn't matter. But I don't know jack about collecting cars.
I never even checked that mine was original, I guess I'll take a look next time I'm under there.
Old 08-31-2007   #5
cuisinartvette
I may take a look under mine this weekend, dont know how to tell if it has, only getting the #s. I can tell someone has had an impact on my crank bolt. Couple that along with a new rad. and some crusted black goo on the backside of my old water pump impeller tells me this thing may have been apart before....Or its on borrowed time, one or the other. Why else would someone mess with the crank bolt?
Im guessing if it was carbon or oil the problem was fixed (or someone added a lot of sealer in a can which never really works) or it would be acting real funny by now.
Old 09-01-2007   #6
93RubyZ
93RubyZ's Avatar
I the study I did, about 140 owners responded and of those, only one engine had been replaced under warranty. All others had original engines with no major failures. On the car that did have the engine replaced, it was done by the previous owner, so little was known about it.
93RubyZ is offline   Reply With Quote
Old 09-02-2007   #7
gbrtng
gbrtng's Avatar
At "The Legend Lives" event at the NCM 4/28/95, Dave McLellan was asked about engine failure rate and he mentioned there were so few failures that there was no meaningful data. Engines under warrantee were pulled and shipped to Stillwater for analysis until LT5 production ceased in 1993. After that shops with certified LT5 mechanics did the warrantee work. I don't know if any factory statistics were kept; maybe Van Dorn can chime in ...
Old 09-02-2007   #8
HADI-ZR1
my zr motor never been touched or repaird till the day i mod. it !
i mean my motor was virgin!
Old 09-04-2007   #9
tf95ZR1
tf95ZR1's Avatar
I'm the one who had the motor replaced at about 25K miles while owned by the previous owner. Good- engine has 25K less miles on it than the odometer says.
Bad- not the original motor (BFD). Good - (2) Birmal heads (BFD).
Cuisin- I found out by doing a dealer service history search. Since it was done under
warranty, the history is available. I believe Tom Henry helped me find the info many years ago.
The dealer where the work was done (Thousand Oaks, CA ) and GM would not reveal the reason for engine replacement.
Old 09-04-2007   #10
cuisinartvette
Thanks Ted...I have a freind who wrotes service over at Rydell, Ill see what he can find on it. Was that you I bumped into last week at Village Coffee Roasters?
