Old 09-06-2015   #1
GSJoe
Default Re: Headlight motors
It's a quick and easy job. I just did it on my godson's '90. I got the gears at VettePros here in Charlotte which is quite local for me.
GSJoe is offline   Reply With Quote
Old 09-06-2015   #2
Gears and or pellets in the motors need to be rebuilt.
How to change the headlight motor gear in a C4 Corvette - YouTube
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 09-06-2015   #3
Intruder
Thanks, guys. This looks like a good candidate for a winter project. I never drive this car at night anyway.
Intruder is offline   Reply With Quote
Old 09-06-2015   #4
1990 quasar blue
Autozone as well as most auto parts stores have these "help" sections that have assorted parts. Look for part number 74410. They're window regulator plugs for fords. In either case they're cheap, local, and fit perfectly. There are videos on YouTube that will give you a step by step. Nothing to it.
Old 09-07-2015   #5
dredgeguy
dredgeguy's Avatar
Second Chance of Wazoo did mine at one of our maintenance days and I purchased part 74410 from Autozone and it costs something like $6. Done in 30 minutes. The 3 original bushings were dust. No need to replace the motor or gear.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 09-07-2015   #6
Intruder
How many do I need for both sides?
Old 09-07-2015   #7
dredgeguy
dredgeguy's Avatar
Each light needs 3 pellets/bushings and I believe the $6 packet from Autozone has 4 so you will need two packs. It has been a while so just check how many in the package.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Old 09-07-2015   #8
Most likely it's just crumbled bushings. Replacement takes about 30 min. each side. I would start with assumption that it's just bushings rather then spend money on motors needlessly.
Stop by Wazoo get together and I'll replace bushings for you and check out the motors.
