Old 10-27-2015   #1
Default Re: Stalling issues - Code 31 (Camshaft Position Sensor)
All the items you listed are fairly easy to check.
I would start with IAC check and reset, TPS easy check with a meter, Map, fuel pressure issues easy just need a FP gauge.
Most if not all this stuff can be found in Dynomite's sticky
This may be a bit out there but what chip is in the car?
http://www.zr1specialist.com/HAT%20W...librations.htm
Also slow down and get the FSM.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-27-2015   #2
MuRCieLaGo
I'm sorry if I feel a bit lost, I've pretty much only worked on rotary engines in the past.
There's no chip in the car, but that will probably be the first mod (after I fix ALL the problems, of course).
Do you think this manual is OK? Not sure if it has info on ZR-1s.
http://www.ebay.ca/itm/311455908176?...%3AMEBIDX%3AIT
I'm actually searching hard on how to test the IAC. One thing at a time.
Thanks We_Gone for your help here and via PM!
Old 10-27-2015   #3
That FSM should have what you need, Their is one more supplement for the LT5
Here are the book #s
ST-364-91 Service Manual covers L98 & LT5.
ST-364-91 EDM Electrical Diag, supplement.
ST-364-91SB Service updates.
ST364-1990/93-LT5-Supp.
When you get them read-read-read
I brought up the chip as GM had a few revisions to address idle issues they should be in the link on Mark's site
http://www.zr1specialist.com/HAT%20W...librations.pdf
Originally Posted by MuRCieLaGo View Post
Thanks! Will buy it then.
Do you think Dynomite's ALDL Code reader is a must to read codes quickly? It seems to be pretty awesome.
A very good tool to have, makes reading codes so much better than the paper clip!!!
Steve
1990 Red/Red #1473
