Old 09-08-2007   #1
Paddy_SP
Default Hub bearings?
My rear right wheel has a small amount of bearing play in it (wheel off the ground, rocked top and bottom). I've searched through this and other sites, but all I can find out is that the whole hub is normally replaced. Since ZR1 hubs are not stocked by many/any places in the UK, I would like to keep the hub and just replace the bearing. Without stripping it all apart to see, I don't know if it is possible - has anyone here any knowledge on the subject?
Paddy_SP is offline   Reply With Quote
Old 09-09-2007   #2
gbrtng
gbrtng's Avatar
Default Re: Hub bearings?
The bearing assembly is replaced as a unit; it cannot be disassembled. The shop manual gives the allowable "play" - some is allowed, so you may not have to replace it yet. And the ZR-1 assembly is the same as ones on the L98 cars.
Old 09-09-2007   #3
Paddy_SP
Many thanks for taking the trouble to reply - it's very helpful to know that the hub is the same as on the L98 cars! Sadly, the play in my wheel is close to the limit allowed by the UK 'MOT' - the annual vehicle safety check, so I'm going to have to sort it out before too long...
Old 09-10-2007   #4
george henry
george henry's Avatar
Greetings. I replaced a rear hub assembly 2 years ago on my 90 ZR1 with TIMKEN hub assembly #513020. Was about $150. No problems since.
Best regards, George.
george henry is offline   Reply With Quote
Old 09-10-2007   #5
Paddy_SP
George - many thanks for the helpful info - I'll look into it straight away!
Old 09-11-2007   #6
Hammer
Hammer's Avatar
Talking Re: Hub bearings?
I replaced mine with a Precision Bearing Part #513013.
