Old 11-25-2015   #1
Default Cam Cover oil leak
I have a cam cover bolt on my 93 that has started to leak, Is it as simple as just removing the bolt and replacing the dowty washer/seal? Its one right above #1 plug wire boot so easy to get at.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-25-2015   #2
Pete
Pete's Avatar
Default Re: Cam Cover oil leak
Yes
Retorque to 15flbs cold engine.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-25-2015   #3
Concur... it's that easy
Old 11-26-2015   #4
Thanks Guys, This was a first for me 3 ZR-1's, 14 years and lots of miles never had one leak any oil!!!
Happy Thanksgiving all
Steve
1990 Red/Red #1473
Old 12-04-2015   #5
Done, and yes it was that easy!! drove around about 30 miles no leak, going on a 200 mile trip Sat that will be the test.
Steve
1990 Red/Red #1473
Old 12-06-2015   #6
Well a 200 mile trip, was still seeping a bit, So this time I replaced the bolt washer and put a dab of sealer on it.... Time will tell.
Steve
1990 Red/Red #1473
Old 12-06-2015   #7
A clogged PCV system could cause Oil leaks in lots of places including the Oil Pan and Cam Covers and the Cam Cover Vent.
Old 12-06-2015   #8
Jagdpanzer
Jagdpanzer's Avatar
If in a hurry loosen it up enough to put three or four wraps of teflon tape under the bolt head and retorque
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 12-06-2015   #9
Thanks, Its just the one bolt above the #1 plug. No hurry I just redid it this AM, I did notice this time the rubber part of the washer protrudes more on one side than the other, so put it up this time against the bolt head also cleaned the seat area with 320 wet/dry to be sure it had no burs.
Steve
1990 Red/Red #1473
Old 03-01-2016   #10
Fixed.. Went out today for a 2 hour drive no leak! Turned out to be the O-ring on the PCV line at the cam cover going to the TB. I just kept finding oil just under the plug area.. Old one was hard as a rock.
Steve
1990 Red/Red #1473
