Old 01-27-2016   #11
oricale
Default Re: Rehab of the 1992 Blk on Blk
One more correction - it's a 94.
Truth in advertising!
fixed...
oricale is offline   Reply With Quote
Old 01-27-2016   #12
oricale
OK...so the burn wasn't sooo small....
entire area you see is brittle to paper-strong...
I am going to SMC the entire side and sand/paint to perfection...OR cut the whole thing and replace it with a donor piece,
melted **** everywhere, water in the floorboards, ect. standard F%ked up car..
I am dyna-matting the whole interior(Like the white car)
This car WILL dominate!!!...just going to take a few months..and about 200 hrs of work..
NOT all bad,...the passenger side is good:
OH YEAH,....found a crack on the cam cover,HIDDEN by RTV....NICE!!!!
[URL=http://s917.photobucket.com/user/oricale/media/20160127_143655_zpsvv1wgh1o.jpg.html][/URL
Old 01-27-2016   #13
What color red?
Correct year Flame Red? or 93 Torch Red?
Originally Posted by oricale View Post
great question,...I have flame red carpet, but the dark red might be awesome!!!.
Flame red is the darker of the 2.. in my picture I have one flame red panel, laying across the torch red panels
Old 02-01-2016   #14
oricale
Update!
After moving the Z06 and the white car to the new shop, I have room to get the 92' on the lift.
Heres the future shop space of Evolution Motorsport Engineering!(half of it anyway-5000 Sq Ft)
First got the tranny out in a few hours,
The speedo-gear was melted and leaking..this MAY have led to the burn, due to the destruction(most of it anyway) was right next to and above.
Old 02-01-2016   #15
oricale
After the tranny, came the engine removal...so far a decent amount of fiberglass damage, burned wires, a **** ton of halon fire retardant and a cracked cam cover. NOT TOO BAD
Going to pull the cam covers, and press on with a "soft rebuild for now,..and also today/tomorrow I will cut out the bad fiberglass and prepare to repair the tunnel, I will then dyna-mat the interior and rubberize/road proof-FIRE proof the underside.
Old 02-01-2016   #16
Lookin good My guess is the cam cover can be repaired?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 02-01-2016   #17
oricale
yeah, I just have to get it off!....gonna have to drill out 5 cam cover bolts just to start!..
Old 02-01-2016   #18
Racinfan83
Wow that looks like a heck of a project! Cleaning all that mess alone is gonna take some hours. Is the trans good still or did the fire kill it? And I would think that cam cover could be TIG welded, and since you were going to refinish anyway it should look like it never even happened..
Old 02-02-2016   #19
oricale
So......I am not sure what to make of the cam cover.....
What do you do when you dont have cam end rubbers??.....Make your own out of aluminum!!!
Engine is coming along:
Soooo... I dont think the secondaries were used for a while:...Those are mountains of carbon in the heads......
Now starting to look and plan the fiberglass repair....
****Also....the Broken cam cover was NOT the original....the PO installed the cam cover and along with the crack/hack job on the cam cover, the rear-outboard cam journal was galled and damaged from the pressure applied from using the WRONG cam cover.!
Due to this I will NOT be using these heads on this engine during the big-cube "Dragon Heart" build
Old 02-05-2016   #20
oricale
Update: Once I got the engine out, I was faced with the standard "frosting" of oil and grime. Note: seems like the oil was from the corner of the passenger cam cover that the PO had mistakenly got electric tape in between the cover and the head...
All of the gaskets were OE, and after a "BIT" of cleaning...
OH Yeah,....I was asked why it wouldnt start........
...After MORE cleaning...
After a bit...(ok alot of thought...I have decided with the much needed help of Phil and Pete to build the 92' into the big cube engine. We will be using the 4" components from phil and after a bit of discussion we will either build the 368 or a bigger displacement.
