Old 02-12-2016   #1
oricale
Default Re: Rehab of the 1992 Blk on Blk
Quick update!
Inside of the drivers side after sanding and rubberizing.
*Rubberizing and Dyna-Mat tomorrow
oricale is offline   Reply With Quote
Old 02-12-2016   #2
rkreigh
you need a B&B to go with that car!
just happen to have one. maybe we can do some horse tradin'
glad to see you bring another one back from the brink
Old 02-12-2016   #3
oricale
Whattya lookin for?????I don't have just 1 horse though....their all tied together...
Old 02-12-2016   #4
Great job, I'ts going to look like new!
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 02-13-2016   #5
Real nice job Demp's
Old 02-13-2016   #6
oricale
Finished up the Rubber and Dyna-matting!..
So for the interior and underside, after the repair to the fiberglass, we:
*sanded and rubberized the underside and Dyna-matted floor joint.
*Removed the compromised joint glue, and re-glued with a black silicone bonding agent(that goop on the right floorboard is OEM...not me)
*Topside was sanded, rubberized the entire floorboard and trans tunnel
*Re-sealed the manual boot ring with the black silicone
*Dyna-matted the floor boards
*Installed a new center console frame
Next up is pulling the dash and installing the Chrome engine.
Old 02-13-2016   #7
oricale
Default Re: Rehab of the 1992 Blk on Blk (Updated investigation)
SO after much interest, The cause of the fire seem to be the VSS, which ether shorted and caught fire or leaked and caught fire. (The 92' that had the same issue had the same type of VSS and was burned in the Exact same area), then once it caught fire it melted/burned the rubber boot around the lower shifter causing the fiberglass damage, as well as traveled up the harness to burn the fwd areas just under the front of the tunnel, until the fire was put out with must have been the entire amount of halon powder allowed in texas.
SOO..I realize it may be a very small portion of vehicles to have this issue ,..however to alleviate any issue that may arise,
To those who still have stock manifolds,..I would recommend:
*Checking the wires(VSS,Reverse lockout ect) to make sure they are not fraying, touching the exhaust,melted ect.
*Put a simple fire barrier in the trans tunnel(dyna-mat, fyre barrier ect)
Old 02-14-2016   #8
bdw18_123
Originally Posted by oricale View Post
SO after much interest, The cause of the fire seem to be the VSS, which ether shorted and caught fire or leaked and caught fire. The 92' that had the same issue had the same type of VSS and was burned in the Exact same area, then once it caught fire it melted/burned the rubber boot around the lower shifter causing the fiberglass damage, as well as traveled up the harness to burn the fwd areas just under the front of the tunnel, until the fire was put out with must have been the entire amount of halon powder allowed in texas.
Actually, if I remember correctly, Evan had said the original owner of the '92 you are referring to that I worked on, put the fire out with one of those giant big gulp type sodas that he happened to have on him. Lol!
