Old 05-22-2016   #11
Hib Halverson
Default Re: Exhaust Backpressure- 3" vs. 2 1/2"
Originally Posted by Hog View Post
Excellent comparison, boy are we spoiled nowadays. (snip)
Mr. Hog gets a Beacon of Reality Award for that spot-in statement!
It would have been nice to see a set of Corvette style BBC manifolds tried as well. The manifolds/Camaro exhaust on the 1969 ZL-1 Camaro with the all aluminum ZL1 427 BBC brought the 500-535hp output of the ZL1 427 down to about 275hp as per testing done at the Tonawanda plant. Chev knew that the buyers of these cars were going drag racing and would be ripping the stock Camaro manifolds and exhaust off of them anyways, so why design a complete new exhaust for only 69 cars.
Point well taken but some of the supporting numbers puzzle me. Using the rating systems of that period, ZL1s made either 560-hp (if you believe unofficial "real" numbers) or 430-hp (if you believe the "official" power rating. No question that when a stock Camaro exhaust was attached there'd be a big loss, but a loss of more than 50%? Not sure I buy that. What testing done at Tonawanda are you talking about? I didn't think there were any dyno cells at Tonawanda back then which could accomodate a full OE exhaust system. Can you post the numbers and the testing method used? Or at least post the source for your info.
I'm sure the 2 or 3 (depending who you're talking to) ZL=1 Corvettes stock exhaust would cut into the power a bunch as well, although there would be more incentive to do a better exhaust for the Vettes, as there was the ZL-1 cars, and the 20 L88's for 67, 80 for 68 and 116 for 1969.
C2/C3s with L88s or ZL1s used the same exhaust system as other Big Blocks, ie: the pretty darn good Corvette BB exhaust manifolds, 2.5-in pipes and the bigger mufflers.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 05-22-2016   #12
CCM is a Chassis Control Module
ECM is an Engine Control Module
PCM is a Powertrain Control Module
BCM is a Body Control Module
Old 05-22-2016   #13
Bob Eyres
Yes, they were delivered with that exhaust system. But the race cars Zora intended them for almost invariably used tube headers, and "off the road" side pipe configuration seen on factory supported L-88's.
I doubt if any part of those systems measured 2 1/2", except maybe the header downtubes.
A side issue- Where did they get that 430hp. figure? It's generally thought that it was pulled out of the air and put in the order form to coax the buyer into ordering the 3 carb 435hp. street version instead of the L88 race motor.
But did they "rate it" by going down the dyno rpm scale until they found the number 430, and rate it at that rpm, instead of where it actually peaked?
Old 05-23-2016   #14
Hog
That's exactly what they did,
L88 number 21550 made exactly 437hp@5200rpm and 560hp@6400rpm on 115 octane fuel running tube headers.
We have to remember that a vast majority of the populous had never heard of a ZL1.
There were only 20 1967 L88s sold. L88 cars also had a laundry list of L88 only(and the following L88 delete) options that helped destine them for race use only.
In Chevrolet sales brochures, in 1969 the engine was listed as a Special High Performance Engine (Off road Application Only Only)
In order to order the L-88, mandatory optional equipment included:
L-88 engine $947.90
J50 vacuum bower booster $42.50
J56 heavy duty 4 wheel disc brakes $42.15$342.30
M22 (rockcrusher 4 speed manual trans $237.00
K66 transistorized ignition $73.75
F41 suspension $36.90
G81 Positraction rear axle $42.15
C48 heater/ defrost delete package credit of $97.85
L88 delete
Further efforts by Chevrolet to ensure its use as a race car, as well as being lighter the following were not available once the L-88 box is checked:
-radio
-power windows
-air conditions
-power steering
Old 05-23-2016   #15
Hog
About the engine testing. I was confusing the ZL1 testing that went on at Tonawanda. After each Zl1 was built, it was run on a dyno in the Test Department where each engine was serialized and was run on a break in program. It was then packed up and taken down to the dynos operated by the Product Engineering Department.(all at Tonawanda). This is where each ZL1 was supplied with its dyno printout of exact engine output. Every engine that left the PED at Tonawanda produced between 500 and 535hp running on Sunoco 260 fuel.(as per Art Casper who worked with the MkIV since its inception at Tonawanda)
Some of these engine were sent to the Chevrolet Engine Center in Warren Michigan where Bill Howell was a development engineer and Tom Langdon(who was a dyno tech) took over for Mr Howell in 1966. Mr Langdon told the story stock Camaro exhaust being fitted onto a ZL1 during ZL1/Camaro development and cutting its power down considerably,
"We did run some checks to see what the performance penalty was. A good ZL-1 when equipped with a standard set of aftermarket headers, would produce somewhere in excess of 500hp, maybe 525hp, without any attention to detail whatsoever. In other words, taking the engine, putting it on the dyno, putting on exhaust headers, and making it run, you wound up with around 525hp, perhaps 600hp with some attention to detail with the cylinder heads, etc, etc. We took one of those engines and and ran it with the released Camaro exhaust system and got exactly half the power with the Camaro exhaust manifolds, exhaust system, manifolds and pipes. So you can see how sensitive the power was to the exhaust system when used with that ZL-1 racing camshaft. Power was cut to something like 275hp." Tom Langdon
The ZL1/Camaro dyno testing was done in Warren Michigan, not Tonawanda. It was other ZL1 dyno testing being done at Tonawanda. I can neiher confirm nor deny your assertion that there wasn't a dyno cell large enough to accommodate an entire Camaro exhaust and engine dyno at Tonawanda.
