Old 05-22-2016   #11
Default Re: Flat Plane Crank LT5
Originally Posted by tpepmeie View Post
Dom,
Imagine the crank throws all on the same "plane", rather than at 90 degrees to each other. Usually it is "up, down, down, up" for the 4 rod journals. Still have a cylinder event every 90 degrees, but they alternate banks (Left, Right, Left, Right, ...). And all the firing intervals are evenly spaced on each bank. Helps exhaust tuning quite a bit, and all cylinders exhibit the same airflow performance. On a 90 degree V-8, certain cylinders can perform up to 8-10% worse than the best cylinder due to exhaust tuning (mainly the closely spaced (90 degrees apart in the firing sequence) cylinders on each side.).
The downside... a considerable secondary shake, in the side-to-side axis. Not as naturally well balanced as a 90-degree crank. And-you can't run a large stroke due to this vibration.
Todd,
Thanks. I thought the name denoted basically a 180 journal config.
Old 05-22-2016   #12
Fully Vetted
Fully Vetted's Avatar
Because of this configuration they are absolutely insane when under boost.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 05-23-2016   #13
David,
Would u explain further why that is?
Old 05-23-2016   #14
Fully Vetted
I believe it is because of two things. It's ability to rev so quickly due to less rotating mass and it's ability to evacuate its exhaust so efficiently. These things are nothing but giant air pumps. If you shove air in, especially under boost, you've got to get air out at the same rate or it robs power.
I did misspeak earlier. The 5.2 is not the Coyote engine. The Coyote engine is an 11:1 compression 5.0L yielding 435HP/390 lb ft of torque. The 5.2L FPC is the Voodoo engine that comes with 12:1 compression and yields 526HP at, wait for it...7500 RPM! With a redline of 8250! IMHO, this is the modern day LT5. A bean counters be damned engine that changes the rules and flips the bird to those that want to play on a level playing field. And the only car this engine is available in is a Shelby.
Here's a great article on the Voodoo engine:
http://www.powerperformancenews.com/...e/#prettyPhoto
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 05-23-2016   #15
mgbrv8
Here is some sound with some revs
https://www.facebook.com/holger.hove...2992382110799/
David Hetrick
Old 05-23-2016   #16
Fully Vetted
Wow.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 05-23-2016   #17
Should we start a "Show us your Crank" thread....oh, uh...maybe not
Old 05-23-2016   #18
Jagdpanzer
Jagdpanzer's Avatar
Sure, here's my 4" Bryant
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-23-2016   #19
Not often you can brag about having a 4 inch crank
Old 05-23-2016   #20
mgbrv8
Now that's funny.
Dave
