Old 01-14-2017   #1
george henry
george henry's Avatar
Question fuel flowing from air intake
1990 ZR1: Started engine but after about 2 minutes it stalled. Tried to restart but no luck. Smelled gas and found large puddle at front of car. Removed air filter and found large amount of fuel coming out of the plenum. Any suggestions? Please?
george henry is offline   Reply With Quote
Old 01-14-2017   #2
Default Re: fuel flowing from air intake
Fuel pressure regulator might be bad or stuck injector pull the spark plugs out to purge out the raw gas so you dont bend a valve
LGAFF is online now   Reply With Quote
Old 01-17-2017   #3
32valvesftw
When that happened to my car it was the fuel pressure regulator, leaking.
Old 01-18-2017   #4
george henry
Thanks for the info. I'll try the pressure regulator first. Anybody else seen this happen?
Old 01-18-2017   #5
I had a similar issue. Turned out to be the fuel pressure regulator also.
Old 01-18-2017   #6
Yes....exactly as you describe......Fuel Pressure Regulators are expensive
Jerry's Fuel Pressure Regulator
Rock Auto Fuel Pressure Regulator
Old 01-19-2017   #7
9T1 Red ZR1
9T1 Red ZR1's Avatar
Hi,
I see two part numbers:
1990 to 1992 is 17112220
1993 to 1995 is 17069632
Are they interchangeable?
Thanks,
Bill
LT5 Red/Red
9T1 Red ZR1 is offline   Reply With Quote
Old 01-19-2017   #8
Mystic ZR-1
Mystic ZR-1's Avatar
Is there any way to replace the diaphragm in the regulator?
That's pretty much the only part in them that could go bad...
Old 01-19-2017   #9
No its unserviceable
Old 01-19-2017   #10
Jagdpanzer cut one up to see if it was serviceable - can't do.
