Old 02-04-2017   #1
bvectra
Default help on the hose
I have a water hose going from one side of the plenum to the other it run over the top of the motor is this needed and is there a cleaner way of running it
I don't see other zr1 with this hook up but i bought the car this way
bvectra is offline   Reply With Quote
Old 02-04-2017   #2
Default Re: help on the hose
This could be TB Bypass.....what is diameter of hose and do you have photo?
This is definitely NOT normal
Old 02-04-2017   #3
I would think I tapped your inj housings for blockoff
Old 02-09-2017   #4
Haibeck sells a pipe that runs under the plenum or if your handy with a tube bender you could whip one up.
