#11 | |
Is there a place to buy one that will fit? |
#12 |
![]() ![]() Join Date: Dec 2003
Chances are with your 368 the DAG was long gone before you cleaned the throttle body. As it was probably enlarged to 63mm.
The other guys are correct, you are not going to find a LT5 throttle body unless its at Jerry's or on eBay, etc. The good news is Marc will rebuild your throttle body, if indeed that is the source of the vacuum leak, and have it back to you within a couple days. I had Marc rebuild mine. I pulled it off and sent it to Marc. He had it the next day and rebuilt it, then put in back in the mail and I had it the next day. I was down for about 3 or 4 days total. Good luck.
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
#13 |
![]() Join Date: Feb 2011
#14 | |
I've done it before, but i'm a little confused regarding draining coolant.. The other times I've pulled it I didn't do that. How/how much should I drain? anyone have a link for the correct procedure? Thank you guys so much for helping me! |
#15 |
#16 | |
![]() Have two new Plenum Gaskets on hand. The Injector Housing Coolant Manifolds should get warm within a minute or two. I would say Block TB Coolant at Injector Housing but I have found very few see the real advantages of that on this forum except for myself ![]() Same goes for Battery Disconnect and making your own oil Cooler Lines ![]() ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-05-2017 at 04:32 PM. |
#17 | |
