Old 03-17-2017   #1
billschroeder5842
billschroeder5842's Avatar
Default Re: ZF fluid change time!
Originally Posted by Roadster View Post
Sounds like you had fun getting the only one!!!
I have extras, so if you want to hold off, or you get stuck getting both plugs out, PM me your address and will be glad to mail one down to you....
Yes, it was. The posted speed limit is 75 so you can get a bit of a running start so the jump up from 75-115 is easy (frankly TOO easy) in the Z.
Thanks for the offer- Hopefully I wont need to PM you!
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 03-17-2017   #2
Roadster
Roadster's Avatar
Many times on the road to Dallas, & Ok City, in sleepers w/UPS. Only thing was our tractors were maxed out @70mph unless we were going down hill....lol I can only imagine what it would be like to run at an extended time in the Z at those (115) speeds. Around here it would only be for a few seconds if that on a deserted road and in the middle of the night.....
Good luck on the fluid change......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-18-2017   #3
Racinfan83
I did mine by myself and on jack stands. 17mm hex which is not hard to find. Like they said - remove fill plug first. I used the funnel and garden hose method to fill it back up. Really wasn't a bad job and yes the trans shifted much better after...
