#21 | |
![]() ![]() This from Marc.......(edited a bit) ![]() For the 1991 through 1993 the Air Bag Sensors do not have to be grounded to work in a crash....they DO need to be attached to the Frame Rails however. The Grounding requirement (Code 16 and Code 26) of the Air Bag Sensors on the 1990 was set up to assure the sensors were attached to the Frame Rails. If the bolts were removed from the sensors the sensor would pass as air bag deployable but would not actually deploy the air bag for obvious reasons. This explains why I got NO INFL REST warning on the panel when I totally removed the 1991 Sensor from the Frame Rail in my test. I am now thinking the Air Bag Sensors on the 1990 ZR-1 will function and Deploy the Air Bag even if not grounded. The 1990 Air Bag Sensors will only appear not grounded/not connected on the panel as INFL REST indicating/suggesting the Air Bag Sensors are not installed when in fact they ARE Installed. To get rid of that INFL REST Indication on the Panel (as well as the Red Seat Belt Indication) requires the Air Bag Sensors be Re-Grounded. I am not going to jar the Air Bag Sensor to see if the Air Bags Deploy to test that theory. If any of the listed faults 21 - 26 for the 1991-1993 were detected in a self test the INFL REST will appear on the 1991-1993 panel. These faults are listed for the 1991-1993 in the ALDL Fault Code Sticky above this technical section. 21 Steering Column Resistance Too High 22 Steering Column Resistance Too Low] 23 Steering Column Circuit Voltage Too High 24 Steering Column Circuit Voltage Too Low 25 Short to Battery in Steering Column 26 Open in Steering Column Now for the 1994-1995 since two air bags are used has different codes and there is NO SIR diagnostic terminal as indicated. The 1994-1995 design requires a TECH 1 diagnostics because the data is sensitive as a result of Government Regulations. On the 1994-1995 ALDL Code Reader when used with Adapter I have noted SIR (the RED BUTTON) is NOT used See Item #3 ALDL Fault Code Reader/Eraser. All other Codes are readable using the 94'-95' Adapter with the ALDL Code Reader. Marc Haibeck ALDL Connector Functional Description
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-02-2017 at 04:19 PM. |
#22 |
Congrats Bill, glad to see you got it fixed. Why don't you make a run down here and fix mine! Lol. Thanks for coming back Dynomite!
#23 |
![]() Join Date: Nov 2016
Thanks for the direction. I tackled the drivers side this afternoon (there is no l could leave one side "not done") as there is no way I could not be symmetrical.
Straight forward with nothing goofy. I did take your advice and clean up connections and grounds while I was in there messing around. I probably could have done it in 90 minutes but it took longer with all the cleaning, wiping, vacuuming, wire brushing, taping.... etc. One less thing to worry about!
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker [SIGPIC][/SIGPIC] Last edited by billschroeder5842; 01-02-2017 at 06:08 PM. |
#24 | |
![]() and yes on being symmetrical .......me also.....had to take a wheel back to Discount Tire the other day to get remounted......turns out I had two left Sawblade Rims for new Nitto 555s. Just bugged me one side did not look like a saw blade ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-02-2017 at 06:18 PM. |
#25 |
#26 |
Does the Info rest light being on affect secondary throttle operation?
Sent from my XT1585 using ZR-1 Net Registry mobile app |
#27 |
No, nothing related.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker [SIGPIC][/SIGPIC] |
