Old 09-09-2017   #1
davekp
Default Delete
Delete
davekp is offline   Reply With Quote
Old 09-10-2017   #2
Default Re: Wanted: '90 Intermediate steering shaft
Intermediate shaft for 90 ZR-1 may be difficult to find. 92-95 shafts are common with standard C4 - rag joint Close to the coupler to the steering rack. Looks like 90 standard C4 intermediate shaft rag joint was more in the middle of the shaft and have resulted in interference with LT5 exhaust manifold - just speculating - resulting in intermediate shaft specific to ZR-1 model.
What is wrong with your original shaft? Perhaps you can buy closest looking intermidiate shaft and use parts to refresh your original?
86-91 intermediate shaft for standard C4. Note that it says excluding ZR-1.
http://www.parts123.com/corvettecent...50f&ukey=15389
Old 09-10-2017   #3
davekp
I think you are right. I need the shaft that has the rag joint at the bottom- due to header interference.
Thanks for the info.
Old 09-10-2017   #4
If you are looking for 92-95 ZR-1, corvette central sells rebuilt ones.
Are you trying locate an intermediate shaft in the middle of hurricane Irma sitting in Florida?
Old 09-10-2017   #5
davekp
Thanks. Yeah, waiting for the hurricane is really boring.
Old 09-10-2017   #6
Ha, ha... I know. I lived in Orlando during the 90s. Stay dry!
Old 09-10-2017   #7
Hope all is well with you...
Old 09-13-2017   #8
I'm not sure if that is correct I replaced mine on my 91 with a low mileage 96 shaft. The MY 90 May be a one off like so many 90 onlys. Also some folks have used the z51 hockey puck style shaft as well but unsure if that was on a z. Be mindful on working in that area as if you rotate it too much while getting it out you could compromise the clockspring and deploy the airbag. That is decaled on the shaft as well but some time those rot and fall off (the warning decal) GC
