Old 11-04-2017   #1
Default A moron needs some help.
I've got a spare alternator I tore apart to rebuild now can't remember what order the 3 collars or spacers go,there are 2 that go on each side of the bearing and one between the fan and pulley. Anybody got the info on this? I've searched the net for a diagram,schematic but can't find anything. Thanks.
Old 11-04-2017   #2
Default Re: A moron needs some help.
Scroll down in this thread for a picture
http://www.zr1.net/forum/showthread.php?t=27876
Old 11-04-2017   #3
Thanks Jerry,that's the one.
Old 11-04-2017   #4
conesare2seconds
Edited, somehow posted in this thread instead of the hypothetical restoration thread, oops.
Old 11-05-2017   #5
WVZR-1
In that snapshot Jerry this would be GM SPO info for the spacers/collars
.396 is actually 10mm x 25.5 diameter GM# 1978064 (WAI 46-1601-1)
.232 is actually 5.8mm x 25.5 diameter GM# 1985999 (WAI 46-1617-1)
If a person were needing these the WAI information would likely be used by all after-market vendors.
Old 11-05-2017   #6
You are amazing!
Old 11-06-2017   #7
WVZR-1
Knowing the dimensions of these two if you were to disassemble a CS144 for an LT5 the 3d on the rotor shaft behind the bearing would be the "other than".
