#21 |
![]() Join Date: Dec 2007
Nice I just picked one up as well off eBay 240 shipped used but in great shape
![]() Sent from my iPhone using ZR-1 Net Registry
#22 |
I love mine, the way it looks and sounds; I'll never go back. I'm going to paint mine slate gray, along with the engine to match my GS wheels.
Sent from my Nexus 6P using ZR-1 Net Registry mobile app |
#23 |
![]() Join Date: Jul 2010
I'd love to see some dyno readouts, or even better some 1/4 mile speed readouts.
I did some back to back testing of a K7N Fuel Injection Performance Kit(FIPK) GEN 2 at the drag strip. I arrived with the stock air intake, then installed the air intake. As you can see this kit starts at the plastic end which bolts o the stock throttle body(75mm) then reaches over to the passenger side where the stock 75mm Mas Air Flow (MAF) sensor is located, one end of the MAF sensor is located inside the sheetmetal box onto which that large oiled K&N filter is located. The metal box is mounted to the inner wheelwell via 2 ruber mounts which allows the entire assembly to "float" around as the engine torques around. The upper opem area of the box actually seals against the OEM hoodliner, leaving an open end where an opening to which the stock air intake was attached. Air comes from inside the fender. The metal box insulates the air filter and air intake tube from radiant heat from my headers. ![]() Which fits on an intake manifold like the ones pictured 3 pictures down, notice the vertical throttle body(this is not the stock 1996-2002 Vortec 350 L31 CSFI(Centralport Sequential Fuel Injection) intake manifold but its from a marine engine which uses the same Vortec 350 L31 cylinder heads which actually uses externally mounted fuel rails and injectors(which is why I installed one) Using the marine intake allows me to get rid of the problematic CSFI poppet valves which look like these. These flow at 23.1 lb/hr at 63 psi of fuel rail pressure. I am now using standard EV^ injectors with USCAR connectors which flow at 25lb/hr@43.5psi or 28.9 lb/hr @ 58psi(4BAR) of pressure. These are actually the same injectors which Todd suggests be used in LT5 apps. ![]() This stock CSFI injection spider does allow for precise injector targeting. Pictured is the actual spray end of one of the 8 spiders legs. That is a mechanical poppet valve ![]() Here is a stock 1996-2002 L30/L31 305/350 intake manifold(right) setting next to a marine intake that has the conventional external fuel rail and fuel injectors. ![]() K&N FIPK installed ![]() I installed a new GM air filter ![]() arrived at the dragstrip at 6:00pm right when they opened up, unloaded and swapped on the slicks and made a hot pass. Then cooled down and made a pass, waited a half an hour and made another pass. Then swapped in the K&N FIPK which took about an hour. Then made a pass, waited a half an hour made another pass, then waited another half hour. I noticed that both 1/4 mile et and mph did not appreciably improve between the stock OEM air intake and filter and then after the K&N FIPK. The numbers did improve, but simply because the ambient temperatures always fall at that time during the Summer and these same improvements have been observed many times previous and since my little K&N air intake test. The biggest observed change was the huge increase in intake noise with the K&N air intake. If you have the hood opened and manually pull the throttlebody open underhood, it literally sounds like an exhaust note. Even in the drivers compartment, the intake noise is much louder, actually sounding quite aggressive when compared to the stock air intake sound which was silent. |
#24 |
I found some dyno data that LOCOBOB had posted back in 2012 from this thread.
http://www.zr1.net/forum/showthread....ighlight=K%26N Here is LOCOBOB's post: Here is the old post from the CF. Results for peak HP were within margin of error but notice the average HP and Torque numbers show a small gain. Today myself and forum member/dyno owner TJ Wong set out to find the truth regarding C4 air intakes. We dyno tested 3 different air intakes on my Lingenfelter 368cid LT5. Tested today were: stock with paper element, stock with K&N element and a cut lid, and finally SLP's "claw" tri-cone filter design. All dyno pulls were made with starting coolant temps at 195 degrees F. Here are the results. Stock with paper, two identical pulls: 477rwhp. Avg. peak HP 477 Stock with K&N and cut lid, three pulls: 471, 475, 480rwhp. Avg. peak HP 475.3 SLP tri-cone "claw", three pulls: 477, 478, 481rwhp. Avg. peak HP 478.7 It would appear that the naysayers are mostly correct about C4 air intakes, not much to be gained here. Both Tom and I were rather suprised with the results. We had expected to see some small but visible gains with the cut-lid and SLP, instead we got a bunch of tests with peak numbers being basically the same or well within normal dyno pull to pull variation. The SLP unit does seem to have a small advantage over the others but suprisingly it's in mid range power not peak (see dyno graph average power #'s). I do know that a few aftermarket companies actually use the 1990-1995 LT5 air filters as the basis for some of their performance air intake and/or hood kits for various makes of cars. But I have just discovered that the air filter is shared between the 90-95 LT5, 92-96 LT1 and the 96-LT4. Hmmm, I always thought the 90-95 LT5 was larger???????? I do know that when dealing with air intakes on the GEN 4 SBC 6.2L LSA, 6.2L LS9 and the GEN 5 SBC 6.2L LT4 and the Ford supercharged engines, that the air intakes make much more of a difference than the N/A engines. ![]() ![]() ![]() Last edited by Hog; 12-19-2016 at 02:50 PM. |
#25 |
#26 |
anyone know where to get replacement filters?
#27 |
![]() Join Date: Feb 2011
#28 |
Just picked up a barely used SLP Cold air intake for peanuts....what is the tube stub for? This came with no instructions....was at SLP website and read this"Using the nylon hose barb, 7" piece of hose, and the two new plastic snap clamps, extend the factory A.I.R. pump supply hose so it reaches the tube stub on the induction tubes. Tighten all three snap clamps.
Mine did not come with a 7 inch piece of hose.... Thanks, John |
#29 |
![]() Join Date: Sep 2016
You do not need to replace them and less they are torn or damaged. Purchase a K&N air filter recharge kit. Cleaner and oil. 13 bucks on Amazon.
#30 | |
![]() Join Date: May 2010
I don’t believe you need to worry about that on our LT5 and maybe for LT1 only? Mine was capped off with silicone cap on both my 90 and 95. IMG_6002.jpg
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() Last edited by HAWAIIZR-1; 06-19-2018 at 11:24 PM. |
