#21 |
![]() Join Date: Dec 2003
Karl i use stock replacement battery.
I think about 30lbs Just looked up Odyssey batteries i like PC950 only 20lbs https://www.odysseybatteries.com/pc950.htm Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 11-13-2019 at 11:33 PM. |
#22 |
![]() Join Date: Feb 2011
Remember the LT5 required 690 CCA according to GM. So choose wisely or carry jumper cables[emoji16]
#23 | |
Google AGM vs Lead Acid battery for more information. It is pretty cold outside and my car is in the garage sitting for over 3 weeks. Car cranks strong, much stronger than the a/c delco that was in there before and fired right up. Besides that daily driving the car before it got too cold outside (no heat in my Z) I never had a problem with charging or starting the car. The battery Pete show's is stronger than mine and weights less by 4lbs. I should have gotten the PC950....argh!!!! Last edited by Karl; 11-14-2019 at 09:29 AM. |
#24 | |
Yes the replacement battery at your local GM dealer parts department is a 650 CCA. After going through 2 of them in less than 5 years, I researched the LT5 690 CCA requirement. The battery that will look stock and fit the battery box is the AC Delco 75VPG Battery. O’Reilly has them for $132. Weight is 33.7lbs. Sent from my iPhone using ZR-1 Net Registry |
#25 |
![]() Join Date: Jan 2004
http://www.zr1.net/forum/picture.php...pictureid=4061
About to try this 8lb lithium ion battery... specs are very similar to the 925
#26 | |
![]() Join Date: Jan 2015
#27 |
#28 |
#29 | |
![]() Join Date: Jun 2013
#30 |
![]() Join Date: Sep 2008
Go on a bread and water diet.
Likely reduce by 50- 75 pounds, and if you don't die, completely reversible after racing. The cars are pudgy; not much you can do about it, without consequence, at least significant improvement anyway. Add more go. ![]() Marty |
