![]() Join Date: Nov 2007
The 90s have straight cut gears in the ZF which produces some gear whine, especially in 1st and 2nd, I find (in my 90 as well). AND, it comes when the clutch is out and goes away when the clutch pedal is engaged. But, if you noise is the opposite, then throw out bearing comes to mind - except seems unlikely with so few miles.
There are many members in your area that might be able to drop by your location and assess the sound with a learned ear. Aside from that, have you changed the transmission fluid yet? Changing the trans and differential fluid - may or may not improve the sound (if coming from the trans), but then you can check that off the list and you'll know that isn't the issue. Perhaps Mark Horner or one of several other local Texicans can give it a listen. And, given that gear whine is the nature of the beast in the 90 to mid 92s, if that is all it is, the fix is turning up the radio or installing headers w/o cats! ![]() |
#2 | |
![]() Join Date: Jun 2005
There are no "straight cut" gears in any version of the ZF S6-40. Gears in the early 6-40s have a slightly smaller helix angle and that's why the early transmissions are a little more noisy and have a little higher input torque rating.
#3 | |
Granted, you've got me beat on the vocabulary front. I had to look up the meaning of "picayune".
![]() Nevertheless, Paul, if you knew a bit more about manual transmissions you'd not say that. I'd like to suggest that when you're making statements about subjects on which you lack accurate information, maybe you should think twice about commenting.
#5 | |
(edit): Everyone...should think twice before saying stupid, derogatory, and unfounded chit on an open forum. Especially the two of us. Sorry for the misunderstanding, Hib. (Shoulda taken my meds first.) Last edited by Paul Workman; 11-25-2019 at 01:57 PM. |
#6 | |
#7 | |
![]() I find that information very interesting....thanks Hib ![]()
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-24-2019 at 08:15 PM. |
