Old 11-29-2020   #1
32valvZ
32valvZ's Avatar
Default Re: 90 Motor Mounts and C-beam plates..anyway to do it WITHOUT removing manifolds?
Originally Posted by Corvette95 View Post
Thanks, about to start the job, any tips on removing the heat shields? Can any be left in place? Any special tools tips for access to prevent slicing up my hands? I plan on removing the entire exhaust as one piece from headers to mufflers, FSM says that is ok?
I dont think you will be able to remove the entire exhaust with the manifolds attached.. I would separate the exhaust from the manifolds back. All that can come out as one piece. I remember having to finagle the manifolds around a little to get them out and I cant see doing that with them attached to the rest of the exhaust.
Im not sure what your working circumstances are.... but I guess you can try if you have a lift that you can stand up underneath. I only have a Kwiklift so maybe thats why it seems easier to separate...
