02-10-2021 | #21 |
Re: Hesitant on acceleration and nothing when you mash the throttle
Just an update....Got the fuel pressure gauge on Sunday....Battery very weak will not turn over....Only charged to 35% and dropping so I need a battery...Had car for almost 7 years now..I guess its about time..
Will keep you posted... |
02-10-2021 | #22 |
02-10-2021 | #23 | |
02-10-2021 | #24 |
Batteries last longer in cold weather states. I use a battery tender, but sometimes they fail or become marginal. I?ll be hunting down a new battery when it is safe for me to shop in public.
02-10-2021 | #25 |
In general I get about 3 years on batteries down here, the heat is a killer. This year I have insulating blankets on two of them, not sure if that will really matter much. On the vehicles I use a tender on it stretches a little. I just went to AGM on two other cars, I hope they last a bit longer.
02-12-2021 | #26 |
Ok fuel pressure at idle is at 21psi...I know it should be around 43 at idle....Did not drive it yet with gauge Attatched....Lots of snow and ice...
Guess the next thing is check the draw on each pump with a multi meter ? Let me know...Thnx for all the help.. |
02-12-2021 | #27 |
Dude, the pump/pumps are done. 21 PSI warm, cold, hot, any reason pump/s = B A D.
02-12-2021 | #28 |
I?d put vacuum on the regulator and see if it holds.
02-12-2021 | #29 | |
It wasn't the pumps....It was a sensor near the headers.....Thought it was the pumps... Will try checking the current with the meter...Pulled hose off regulator and its dry...No fuel leaking if that helps... |
02-12-2021 | #30 | |
Sent from my SM-G950U using ZR-1 Net Registry mobile app |
