Old 08-29-2021   #1
Vettemann98
Vettemann98's Avatar
Default Broken upper mounting bolt rear shocks
Sheared off head of one of the two upper mounting bolts trying to remove to inspect rear actuator function. Any suggestions on how to remove bolt? Easy out kit? Other?
Many thanks, Scott
[SIGPIC][/SIGPIC]
Vettemann98 is offline   Reply With Quote
Old 09-05-2021   #2
Vettemann98
Default Re: Broken upper mounting bolt rear shocks
Well I actually got it out using an extractor kit and drilling. Was able to back it out enough to grab it with vise grip pliers and slowly back it out. All afternoon process.
[SIGPIC][/SIGPIC]
Old 09-05-2021   #3
Vettemann98
[SIGPIC][/SIGPIC]
Old 09-06-2021   #4
Good work! All afternoon but a satisfying result I am sure. --Bob
Old 09-06-2021   #5
Vettemann98
Yes what a relief!
[SIGPIC][/SIGPIC]
Old 09-06-2021   #6
HAWAIIZR-1's Avatar
Originally Posted by Vettemann98 View Post
Yes what a relief!
What are your plans to get a nut up there to put the bolt back? I will be doing coilovers soon and hoping no issues. Glad to see you got it out okay.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 09-06-2021   #7
Vettemann98
Fortunately I was able to drill into the bolt after many attempts and it spun out enough for me to grab each side and turn it counterclockwise to back it completely out w/o damaging the welded nut above the hole. I then replaced with M8 nut per M. Haibeck suggestion and it screwed right in no issues. As your indicating there is zero access to that nut as it?s completely enclosed by a rectangular metal frame. M Haibeck states he often drills a small hole next to where the bolt is at on that frame to spray rust buster prior to removing upper mounting bolt to prevent what happened to me. Apparently he has a way to weld a nut in that space but it is a prolonged time consuming event as he related to me.
[SIGPIC][/SIGPIC]
Old 09-06-2021   #8
Vettemann98
BTW Im pretty sure it was you who had a post about wheel stud guides to assist with putting wheels back on ZR-1. THANK YOU. Its one of the best tools that I have to get those freakin heavy wheels back on without damaging the rotor assembly and most importantly my back.
[SIGPIC][/SIGPIC]
Old 09-06-2021   #9
HAWAIIZR-1's Avatar
Good news. Thanks for sharing. I thought the welded nut was done. What a relief for you. I can imagine how difficult it would be to get a nut welded in there. Good job on this.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
Old 09-06-2021   #10
HAWAIIZR-1's Avatar
Roadster (and then some?..Tom)on there was the one that told me about the slick stud extension thing a ma bob. You?re welcome. Best thing since sliced bread for sure. I?m glad it helped you too.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
