Old 09-16-2024   #1
bmarcum
Default Bringing the Champ back to fighting condition
Ok. I have been driving my 90 Z VIN1965 and it has not been a driven car for 24 years. Not sure the history and why it wasn't driven but for all signs (oil tags, and condition) it not been a sports car for 24 years.
I have a miss that is weird. It only misses when the secondary are on. It seems to only miss when warm. Still trying to confirm warm only miss.
Thoughts on what I am chasing. I don't have a scope for LT5 waste space, so I can't tell if it is a cylinder or a bank that is missing. I have not pulled the plugs yet. But it is very intriguing that it does not miss with secondary off. Thoughts? I am a big one for diagnosing then fixing vs just changing plugs and wires especially pulling the intake. Thanks to all my LT5 friends!
bmarcum is offline   Reply With Quote
Old 09-17-2024   #2
Starman
Starman's Avatar
Default Re: Bringing the Champ back to fighting condition
You probably have one or more bad secondary injectors. There is a way detailed in this forum to check them at the ECM harness. If bad, replace them all. The original injectors are not ethanol resistant and short out. About 93 on did not have this problem.
Old 09-17-2024   #3
Starman
Starman's Avatar
As I recall you are looking for around 14 ohms resistance.
Old 09-19-2024   #4
Mystic ZR-1
Mystic ZR-1's Avatar
Replace the coils while you're in there....
Mystic ZR-1 is online now   Reply With Quote
Old 09-20-2024   #5
bmarcum
The buyer I purchased it from said injectors had been replaced, but I have no documentation. It really feels like ignition, but it is strange that it will only miss on the secondaries. Just curious if the fuel mixture could be such that it would not miss on primary but miss under a load on secondaries with a full cycle charge needing more voltage. I am thinking maybe wires when the motor get heat soaked. I really like the OEM coils and have run them for a long time with no issues. I have had problems with MSD etc Chinese coils that were new.
Thoughts on wires being the problem? I will replace unless someone scope suggestions.
Other injector problems I have had on previous car would have bad misses at idle. This feels like ignition, but so weird it only on secondaries.
Anyone have a scope for wasted spark they like for LT5?
Old 09-21-2024   #6
You probably have weak spark on 1 or more cylinders. It can occur on a single cylinder. The weak spark condition is not noticed during low RPM driving but will be noticeable under load as a misfire. It is most likely a coil, not plug wires.
There are 2 simple tests to determine if this is the case. I suggest conducting both to verify and isolate the cylinder(s) affected.
1. Load test in 6th gear at 35-40 mph, lug the engine. When you accelerate, not pedal to the floor, but 1/4 to 1/2 pedal, it chugs. If all is right, the LT5 will accelerate smoothly during this test.
2. Best done in shade or low light. Test spark by pulling one wire, attach a spare spark plug & lay it on the plenum to ground. Start the engine, hold the boot & observe the spark as you raise the plug. You should see a 1/2" long bright blue spark. An orange spark denotes weak spark. Repeat for all cylinders.
There are a few reasons for a single cylinder weak spark. The solution is to replace the coil. Your option whether to replace one or all four.
When replacing the coil(s), I recommend cleaning all the spade contacts on the coil base. Apply a light coat of dielectric silicone grease to the contacts before installing coils. Likewise, lightly lube the coil terminals & inside the wire boots.
Old 09-21-2024   #7
bob@tradeshowconsulting.c
I believe Dielectric grease should not be put on metal contacts in most cases
especially if there is little chance of water exposure .. Its actually one of those Myths people keep perpetuating ..
Here is a better explanation I found online..
Dielectric Grease
"It doesn?t conduct electricity, it?s a high resistance goop that?s meant to seal out water and contaminants. There?s only two places it belongs on a car. One is on the spark plug boots because they?re sensitive to moisture, need a bit of lubrication for install/removal, and are a super high voltage system that has the ability to arc if anything is slightly wrong. The second spot is on your trailer plug or winch/plow connections, especially if you launch or retrieve boats in the ocean or plow in the salt belt. There is no reason or advantage to using it on any other connection on a car. Most automotive multipin connectors have rubber seals in them to keep out water. Large cable connections should be kept clean and tight with no dielectric grease. Only hacks and people who don?t know what they?re talking about put it on everything and it?s honestly very frustrating as a professional tech to deal with junk that?s been molested by people who smear on it everything."
Again.. the quote above is not written by me .. and no offence to anyone ... just FYI..
For the most part it should only be put on rubber boots /connectors and not the metal-to-metal contacts because by nature and by name it prevents electrical contact .. I was told by an expert automotive electronics guru not to put dielectric on spark plug terminals and metal connectors years ago ..
My 40th ZR1 is 100 % bone stock .. 27K miles and runs perfectly ... and yes I am expecting to have to change the coil packs at some point ..
I hope you find the solution to your problem... these threads help us all
Thanks
Bob V
bob@tradeshowconsulting.c is offline   Reply With Quote
Old 09-22-2024   #8
Dielectric Grease
Thanks
Bob V
One Bob to another, I will say that I agree with you. Dielectric grease should not be used in electrical connections because it does not conduct electricity. Should be used to keep moisture out. I have used it on spark plug boots (even way back to my '68 Hemi Roadrunner) and as a lubricant on the rubber gaskets of my targa tops. Not much more. --Bob
Old 09-23-2024   #9
Point made and well taken. However, I recommend it on terminals, NOT for conductivity but rather prevention of oxidation & corrosion which is damaging to metal parts and thusly the conductivity of the metal to metal contact. If a conductive lubricant is needed, then the contacts either are failing or have failed.
Di-electric/silicone grease is also good to apply to the weather seals, because it keeps the rubber pliable & soft, enhancing its ability to seal. I have used it on weatherstripping with much success.
I do not recommend it on any part which seals or comes in contact with the fuel system. The silicone will permanently damage the catalyst.
Having said that, what other type of grease would serve the same purpose on contacts & terminals? I am always receptive to new lessons.
