Old 05-05-2008   #1
Jeffvette
Default Stainless Works headers
Was working on installing a set of headers and came across a not so small issue.
Be warned the pictures are large.
http://www.pnwzr1.com/images/SSW_Headers/IMG_1253.jpg
http://www.pnwzr1.com/images/SSW_Headers/IMG_1254.jpg
http://www.pnwzr1.com/images/SSW_Headers/IMG_1255.jpg
Shot 1253 shows the interference with the steering rack and also the gap
at the end with the flange and the cylinder head end.
Shot 1254 shows the center stud and that the header can not move any
further back from that point, and also the amount of bolts I was able to
get on to help center the header.
Shot 1255 shows the driver side rear bolt holes and how the line up with
the cylinder head.
Currently the headers are on there way back to SSW. They agree there is a issue, and need to figure out why as the flanges are cut on a CNC machine and the headers are assembled on a jig.
Old 05-05-2008   #2
Polo-1
Default Re: Stainless Works headers
Time to get the drill and smoke wrench out
Old 05-05-2008   #3
the cylinder head.
Do you see this problem with jeals?
Old 05-05-2008   #4
Jeffvette
Nope, but I haven't seen a set of Jeals in a long time.
Old 05-05-2008   #5
Zr1 Destroyer
Zr1 Destroyer's Avatar
Interesting! I just got done cutting down the top of of my motor mount on the drivers side! I noticed while wrenching my motor mount bolts back down that the mount heat cover had got a little crispy. Removed it and noticed the header resting on the top corner of the mount.....I tried to adjust it, but was not enough so I had to remove the mount and file it down to get only about an 1/8" of clearance......wierd!
Zr1 Destroyer is offline   Reply With Quote
Old 05-06-2008   #6
Just put a set on my 91 a few weeks ago. everything fit good.
Old 05-06-2008   #7
lbszr
lbszr's Avatar
Two years ago mine fit good except 1/16" clearance to steering shaft and touches on right turns, which is kinda irritating since it can be felt, close but not touching engine mount insulation.
Old 05-06-2008   #8
Jeffvette
Good to know, this is the first set I've had issues with on the flange. I had some issues with mine that are on my car, but they were one of the first ones from SSW.
Old 05-06-2008   #9
Jeff,
I just got this set from SSW on 3/28 ordered them the first of Feb. took about a month as they had to make them and send them out for coating. Got around to putting them on 2 weeks ago. Everything went normal as far as header installs go. The fit was good all the bolt holes lined up very nice. The fit near the steering shaft was close but still had about 3/8 inch of clearance. As far as the left motor mount they do touch the insulation but nothing more. On the right side the only close spot is the frame rail with about a 1/16 inch clearance. Looks like someone did not get the jig set up right on the set you are working with.
Old 05-07-2008   #10
tf95ZR1
tf95ZR1's Avatar
I was lucky and found a set of Jeals. Not only fit well and good clearance,
but could use the stock oil dip stick tube and oxygen sensors.
That was not the case for Jerry who had some issues with his Jeals.
Sounds like its just the luck of the draw.......
