Old 06-19-2008   #11
jonszr1
jonszr1's Avatar
Default Re: Dyno run sheet
wow, you are lean , is dominic going to add more fuel for you. O would be very carefull till he or someone does . my car was like that till corey added more fuel and took out 1-2 deg of timing up top. the reason for the timing was californias wonderfull 91 oct fuel and special adiitives .id bet you would go over 400 whp easy with the right fuel curve.it shows you did a very nice job on the porting
Old 06-19-2008   #12
Sweet part is 390rwhp with a crap tune......this could be fun!
92 ZR1
#234
Old 06-19-2008   #13
92 ZR1
#234
Now you need to learn to control it
Old 06-20-2008   #14
Aurora40
Aurora40's Avatar
I'm no expert, but I've heard tailpipe widebands read lean by about half a point or so? So it might not be quite as bad as the 13.9-14:1 seems to indicate.
Also, wouldn't you lose a little power richening it up (though gain a huge margin of safety)? All I mean is a non-crap tune might not improve the power, though it certainly looks like it would be a good idea.
So do you have headers or what?
Old 06-20-2008   #15
yes I am runnning Watson headers.
92 ZR1
#234
Old 06-20-2008   #16
jonszr1
jonszr1's Avatar
I think his car being that lean would cost power. it looks way lean , it would be fun to see what happens when they add fuel .if i had to guess 410to the wheels .but i am no expert
Old 06-20-2008   #17
A40,
The best place for a WB is in the collector next to the NB sensor. I think next time I go to the dyno, I'll have my ZT-2 hooked up. Be an interesting comparison between the tailpipe and the collector. My first run on thedyno showed a 13.4:1 AFR. Dropping that to 12.8 did nothing for power either way but a bit more peace of mind in case of bad gas for example.
