Old 06-25-2008   #1
jerrydirks
Default Flywheel Balancing 1992 ZR1
I have recently discovered that there are no weights in the flywheel and there is noticable vibration above 5000 rpms. I have the flywheel out of the car, were the weights meant for balancing only the flywheel or was the balancing performed for the flywheel and engine combined?
Would having the flywheel/clutch balanced alone be sufficient?
Has anyone had there engine and flywheel balanced in the car?
Any help is greatly appreciated!!!!!!
Jerry Dirks
1992 DRM 600 Minnesota
jerrydirks is offline   Reply With Quote
Old 06-25-2008   #2
WVZR-1
Default Re: Flywheel Balancing 1992 ZR1
Is it the same flywheel that you've had in the car and driven previously? Is your clutch "new"? Is the vibration "new" or you've not driven the car previously? I'll be interested in responses!
I'd be interested in how you accomplished the repair/rebuild/weld or whatever of your transmission case? I hadn't seen you get back to that thread.
Old 06-25-2008   #3
jerrydirks
I am still sorting out the transmission repair. The flywheel was in it since the DRM mods....I think they did not transfer the weights. Clutch is stock. The vib was present before the broken trans.
Since I have the driveline in pieces I thought I would try to remove the vibration that has been present since I bought car last fall.
Thanks for follow up.
Old 06-26-2008   #4
One other item comes to mind, and that is the drive shaft balance. Were the U joints recently changed? I know how difficult it can be to keep those little "needle bearings" in place while installing new U joints; installing them is an art. The FSM goes into some detail, but a drive line company could take your drive shaft and trans yoke and check the balance/rebalance as necessary. That would eliminate that part.
As for balancing the flywheel, it sounds like that too would be something you might want to send to a machine shop and have checked out.
Bottom line: BTDT and balancing that stuff made a huge difference on another project of mine (many moonz ago). From my experience, it is "SOP" to have the FW and pressure plate balanced together whenever a new clutch is installed. The trick is finding a place that can do the work.
Good luck. Let us know what ya come up with!
P.
Old 06-26-2008   #5
jerrydirks
The flywheel and clutch that were in the care b4 the trans breakage were in it for 12 years, 14k miles. The drive shaft is new but the vibration followed engine speed in each gear.
Does anyone know if balancincing the rotating mass, flywheel, clutch, how GM approached the balance issue or should the balance be performed while on the engine crankshaft?
Thanks!
Jerry
Old 06-26-2008   #6
WVZR-1
I was curious if the "original" DRM 600 package that I thought was a 368" and included a crankshaft might have the assembly balanced and there likely wouldn't have been weights? Don't know!
I couldn't imagine that critical an "operation" would have been "overlooked"! The balance of the driveshaft is an inexpensive "to do"!
I'd maybe check with DRM on the original build! If doing a new clutch I think most would agree, check the balance. Clutch assembly quality isn't exactly what it used to be! Confirm your "new" clutch is correct also, there's been some mispackaged goods around and assembly problems posted here and also on the other forums! Check the P/P with a machinists straight edge! I'd check the spring "color" if they're colored, if they're not all the same color it's a quick cause for concern!
* I believe the current DRM 600 is a "402"!
Old 06-26-2008   #7
jerrydirks
This DRM was performed in 1996, dyno at 589 and 500tq is 385 CI. The inbalance was with the original clutch assy and flywheel. Driveshaft was new replaced before trans cracked. I believe that the vibration hastened the trans breakage.
Jerry
Does anyone know the purpose of the urethane that is applied to the trans and diff connections to the c channel???
Old 06-26-2008   #8
Jerry#397
Jerry#397's Avatar
Jerry,
Don't know the details of the vibration you posted on but I will tell you that I had a vibration for a couple of years that I could not locate. Took the car to a restoration shop for a steering wheel pin replacement and while there had them check for the mystery vibration. Turns out that it was the Harmonic Balancer (believe GM calls it a Torque Dampener). Really a PITA to check it out with a mirror, etc. and to change it is another PITA. The "Dampener" also has balancing weights (pins) that must be replaced in the same slots on the new part.
It's worth checking, could be part of the problem.
Thanks,
Jerry
Jerry#397 is offline   Reply With Quote
Old 06-26-2008   #9
Zr1 Destroyer
Zr1 Destroyer's Avatar
Thanks!
Jerry
No...the lt5 is internally balanced meaning the crank/rods/piston were balanced and the balancer and flywheel were not used for the lt5 balancing. The only way the balancer could become out of balance if it was hit or the motor was removed maybe after rippie originally and the balancer slammed into the cross member...so I doubt the crank balancer is out.
If the pilot bearing went out or was damaged in the rear of the crank and car was driven for a while like that you will get a vibration since the front of the tranny shaft sits in it! I did my clutch in my first 90 zr1 and messed the pilot bearing up and it vibrated bad until I removed the tranny again to put a new pilot bearing in the end of the crank and the vibration was totally gone afterwards!
Zr1 Destroyer is offline   Reply With Quote
Old 06-26-2008   #10
Polo-1
Yes, It's internally balanced. But it's also dynamic balanced with pins in the front dampener and the flywheel.
Part#10174322 for the front no longer available.....
Call Jeff I think he is working on replacements
