Old 07-27-2008   #2
Jeffvette
Default Re: bad window, bad rear window gasket, bad cd player, bad seats....no treat for car
Originally Posted by ZRGator
I have a non functioning driver's side power window, a non functioning cd player, non functioning sport seats and a bad rear window gasket
Window, depends on what the issue is, minimum you need a volt meter to check the switches.
CD player, you can remove it, but suggest sending to dr don for repair www.doctordons.com
What part of the seat is not functioning?
The rear hatch weatherstrip, you can do yourself it's simple. May take 30 minutes at most.
The last time I started it (about a week ago) I also had a hellacious squealing noise under the hood that got worse when I hit the pedal....eventually went away but should I suspect a bad water pump here?
Change your belt recommended belt Goodyear 406085, also listen to the pullies to see if onen has a bad bearing.
