#11 |
I don't mind making my own vacuum lines. Where is a good place to get the lines and fittings and such. Is there a thread anywhere showing how to do it?
#12 |
the the air duct will collapse if you have the stock one, you need to reinforce it somehow. Since it seems the inexpensive ones are no longer made a coffee can cut down the side with the bottom taken out inserted inside the duct will work
#13 |
![]() Join Date: Dec 2004
Not to be a cheap s.o.b. but my pump was corroded & I took it apart & cleaned it up & now it works just fine. Check the plug for it & if it has melted plastic then the insides of the pump are corroded from moisture and it's a bit seized up. A little contact cleaner & some patience on the electrical connector should put it right. Same thing with the inside parts...just the moisture over time and if you clean it up, it should work just fine.
I'll post up the p/n of the truck pump when I get to my tool box & look at my inventory sheet. ![]() Have the injectors been done? May want to think this thru slowly about all the "wear" items that are antique under there: actuators, tank, control solenoid, CCVB gasket, CCVB hoses, temp sensors (ECM & Gauge), coils....etc, well you get the idea, right, I could go on and it can get expensive in a hurry. If you want p/n's on this stuff let me know as I think I have most of them. Good luck with your new toy & welcome to the BOB! ![]() Tom
#14 |
Thanks for the tip, I did plan on taking the pump off when I get the car back at the end of this week. I teach electrical and electronics so if it is just seized up from corrosion and such I wont have a problem taking it apart and cleaning it up, but I would like to have the part number for the new one just in case. It would be appreciated if I could get a list of part numbers for all the vacuum stuff under the plenum too.
#15 |
GM Part #94669091.
Your local dealer can get one, or you can get it from P & G Chevy. Don't wait 'cause the price is going up slowly. This part was an exact fit on my '91, nothing to change or modify. |
#16 |
I have all receipts of the work done to the car so it doesn't look like the injectors have ever been replaced. While I have it all apart I'll be sure and address the air duct too.
#17 | |
![]() Join Date: Aug 2006
#18 |
I remember the duct collapsing was a problem on C5 cars if you were running boost. But if it doesn't restrict airflow and is easy to do I guess it wouldn't hurt to give it some support. Imports do the coffee can exhaust
#19 | |
#20 | |
Here is the best information I have found when attacking the same issues. |
